Skip to main content
Robot Configurations
When selecting an industrial robot there are many things which need to be considered, such as: what is its purpose, how fast does it need to move, what precision of movement does it need, will it be a collaborative robot? All of these considerations, and many others, determine the type of industrial robot which is best for a job.
One of the major factors which determines how an industrial robot will move and what limits its workspace is its robot configuration. There are six major types of robot configurations: Cartesian, Cylindrical, Spherical, Selective Compliance Articulated Robot Arm (SCARA). Articulate, and Delta (Parallel).
Some industrial robots may not be able to scratch the back of their forearm with the same hand, just like most people can not perform this task. However, through the attention to axes and the selection of a configuration, industrial robots can be designed to move their tools quickly, accurately, and repetitively to any point within a three dimensional workspace.
Robot Configuration Explanation Common Uses
Cartesian Has the robot’s tool moving in a linear motion along each of the Cartesian coordinates (x, y, z). This type of configuration can sweep out a box-like work envelope. Many 3D printers have their print nozzles mounted on a Cartesian configuration.
Cylindrical Allows its tool to rotate around a central axis. The tool can also move towards and away from the central axis, plus up and down the central axis. This configuration creates a work-volume in the shape of a cylinder. This configuration is typically used for assembly operations, handling of machine tools and die-cast machines, and spot welding.
Spherical The tool motion created by this configuration sweeps out a workspace shaped like a sphere.  It has its tool rotate around a central axis, and the tool can also rotate around a second axis which is placed at a 90 degree angle on the central axis. In addition, the tool can move back and forth along an axis. They are commonly used for die casting, injection molding, welding, and material handling.
Selective Compliance Articulated Robot Arm (SCARA) Uses pivot points to allow its tool to move in a combination of the Cartesian and the cylindrical motions. This allows the tool to move more quickly, and move more easily in certain motions, such as moving in an arc. SCARA robots are used for assembly and palletizing, as well as bio-medical applications.
Articulated This type of robot is the most commonly pictured when referring to an industrial robot.  As a minimum, it needs to have at least a shoulder joint, an elbow joint, and a wrist joint. Many examples of these configurations can have both major and minor axes. Typical applications for articulated robots are assembly, arc welding, material handling, machine tending, and packaging.  The VEX V5 Workcell is an example of an Articulated configuration.
Delta (Parallel) Can move the robot’s tool the fastest of all of the robot configuration types. It uses parallel linkages to allow its tool to quickly sweep out its workspace. A Delta can nimbly and quickly pick and place items in a sorting task, as well as serve in many other functions.
