Skip to main content
Answer Key
Summative Assessment Answer Key
  1. Which type of movement is best suited for picking up and placing disks with the arm mounted on the VEX V5 Workcell?
    Joint
  2. Which of these is best described as “the relationship between all of the forces acting on the robot and its motion?”
    Robot dynamics
  3. Which type of movement is best suited for drawing a hexagon with the arm mounted on the VEX V5 Workcell?
    Linear
  4. Which type of movement is depicted in this image?
    Joint
  5. Which type of movement should be used to draw the following three points in a straight line?
    Linear
