Skip to main content
Lesson 2: Mini Challenge
Mini Challenge
For this mini challenge, create a project where the VR Robot picks up and drops each of the blue disks into the blue goal on the Disk Mover Playground.  Use the energize command and Drivetrain commands to instruct the VR Robot to drive to each blue disk, pick up the disk, drive back to the start, and drop the disk in the blue goal.
A top down view of the Disk Mover Playground with the VR Robot in the blue goal in the lower left corner, and the three blue disks highlighted with a red box, illustrating which disks should be collected in the challenge.
Follow these steps to complete the mini challenge:
  • Watch the solution video to see how the VR Robot should drive in order to complete the mini challenge. In this video clip, the VR Robot begins in the start location in the center of the blue goal in the lower left corner. It drive forward to pick up the first blue disk, then in reverse to drop the disk in the blue goal. This is repeated two more times until all three disks are collected in the goal area.
  • Create a project by adding or removing the necessary commands to the Unit8Lesson2 project.
  • Start the project to test it.
  • If the project is not successful, edit and try again. Continue to revise and run the project until the VR Robot successfully picks up and drops each of the blue disks into the blue goal on the Disk Mover Playground.
  • Save the project once the VR Robot successfully picks up and drops each of the blue disks into the blue goal on the Disk Mover Playground.
Questions
Please select a link below to access the lesson quiz.
Google Doc / .docx / .pdf
