1733240556
Skip to main content
Compete
Now that you have built and tested manipulators for your Robot, you are ready for the One-on-One Robot Soccer Challenge. The goal of this challenge is to score as many goals as possible in 60 seconds! The animation below shows an example of how to set up the Field and begin the competition.
In this video, two Clawbots start on the field, with a robot one square away from opposite corners. Each team begins near their goal that is represented by a gap in the Field's walls. The robot on the left is identified as the red team, while the one on the right is identified as the blue team. A timer counts down from 60 seconds as the robots drive around the field, attempting to move a red Buckyball to the opposing team's goal to score a point. The robots can push against the robot on the opposing team, trying to block them from scoring or take the Buckyball for themselves. The points are totaled for each team, and at the end of the match, the red team wins with 2 points to 1.
Follow the steps in this document to complete the One-on-One Robot Soccer Challenge. Google / .docx / .pdf
Once you have completed the One-on-One Robot Soccer Challenge, check in with your teacher. Ensure you have documented the results of the challenge in your engineering notebook.
Wrap Up Reflection
Now that you have created a strategy and competed in the One-on-One Robot Soccer Challenge, it is time to reflect on what you have learned and done in this Lesson. Start a new page in your engineering notebook to begin your reflection.
Rate yourself as a novice, apprentice, or expert on each of the following concepts in your engineering notebook. Provide a brief explanation for why you gave yourself that rating for each concept:
  • Designing, building, and iterating on your manipulator
  • Using the manipulator to move the Buckyball to the goal in One-on-One Robot Soccer
  • Collaborating with my team members to come up with a strategy combining game play and manipulator design
Use this table to help you determine which category you fall under.
Expert I feel that I fully understood the concept and could teach this to someone else.
Apprentice I feel that I understood the concept enough to compete in the challenge.
Novice I feel that I did not understand the concept and do not know how to complete the challenge.
What is Next?
In this Lesson, you learned about active and passive manipulators and how they can be helpful on a robot. You built and iterated on your manipulator design, and competed in a One-on-One version of Robot Soccer. Now it is time to compete in the Robot Soccer Competition!
In the next Lesson, you will:
  • Go over the rules of the competition
  • Develop a game strategy
  • Compete in the Robot Soccer competition
Three Clawbots on the EXP Field playing Robot Soccer. One Clawbot has a Buckyball grasped in the claw and is scoring it at the edge of the Field, the other two robots are chasing behind.
Select < Return to Lessons to go back to the Lesson Overview.
Select Next Lesson > to continue to Lesson 3 and learn how to participate in the Robot Soccer competition!
