Skip to main content
VEX IQ Session 6
It's time to get ready for your first competition day! A VEX IQ Robotics Competition event involves more than just playing a match. In this session you will walk through some of the main parts of a competition, so you know what to expect. Every event is a little different, but there are things you can practice so you feel prepared when you arrive.
By the end of the session you will know what you need to do to be ready for competition day!
Checking-in and Preparing Your Pit
When teams arrive at a competition, they must check in. Your coach will check you in, and get information about the day, like the inspection sheet, match schedule, and pit map.
Your team's pit will be like your home base for the day. It will be labeled with your team number. This is your team's area to work on your robot and strategy between matches. This is also where judges will come to find you for interviews.
You will need to bring everything you need from your team's space with you to the competition. This includes things like:
  • Your robot and controller.
  • Extra batteries.
  • Your VEX IQ Competition Kit, extra pieces, and Pin Tools.
  • Your engineering notebook.
Three students carry their IQ Robot in a plastic container. Behind them is a set of bleachers and a person in a black and white striped referee jersey.
Now it is your turn to pack and prepare for the competition! In this activity you will look at what you are used to having in your team's space, and make a packing list of what you will need to bring to the event.
Use this task card (Google doc / .pdf / .docx) to help you get ready to set up your pit.
  • Talk with your team and coach about everything you do in a regular team meeting, and what materials you use.
  • Ask your coach about how you are getting to the event, and talk about how you will get your robot there safely.
Inspection
Inspection is a process in which volunteers check a robot against the rules and requirements in the game manual to make sure the robot is allowed to participate in matches. There will be an inspection area at the event that you will bring your robot to at the start of your day.
Robot inspection makes sure that all robots are following rules related to size, parts, and software. A robot must pass inspection in order to participate in matches.
This inspection checklist can help you make sure your robot will pass inspection. Print it out and check each item on the list as you prepare for your first event. You can also refer to the game manual to learn about inspection rules.
2 team members observe as a third uses the IQ sizing tool to check the size of their IQ robot at a competition.
Next, your team will practice the inspection process to make sure that your robot will pass inspection at the competition.
Use this task card (Google doc / .pdf / .docx) to guide you through inspection.
  • Make sure your robot meets the inspection criteria.
  • Note any action items that you want to fix before the competition on your task card.
Teamwork Challenge Matches
Your team will be paired with another team to make an alliance for each match that you play. Together, you will try to score as many points as you can in a 60 second match. Each team has two drivers, and the controller is handed off mid-match.
Your team will play several matches at the event. To begin, you will be randomly paired with another team as an alliance partner.
  • The match schedule shows the time, location, and your alliance partner for matches.
  • Find your alliance partner before the match to develop a game strategy.
  • Keep track of the current match number being played, and arrive at the queuing area early with your alliance partner.
A team celebrated at the end of the match on the field, very excitedly, as onlookers cheer.
Now that you've gone through inspection, it's time to get ready for a match! In this activity you will walk-through the things you need to do in competition match.
Use this task card (Google doc / .pdf / .docx) to guide you through your practice match.
  • Make sure you are on time for your match based on the match schedule.
  • Review the rules and scoring so you can be confident in checking your score with the referee.
  • Remember, your coach cannot be with you at the Field during a match. Your team is responsible for match play and speaking up for yourselves after the match if there is a question about the rules or score.
Engineering Notebook Judging and Interviews
Your team uses your engineering notebook to document all of the work you've done to design, build, and improve your robot. The team's engineering notebook and summaries will be turned in when your coach checks in at the event, so that it can be judged. Your team may also be interviewed by the judges during the event.
Throughout this STEM Lab, you have been documenting your data and progress in your engineering notebook. You've also practiced using the Student-Friendly Engineering Notebook rubric to help get your notebook ready for judging at the VEX IQ Robotics Competition. Now you will take one more look at your notebook to be sure it is ready to go.
Engineering notebook pages with game field sketch and notes.
Team Interviews
Interviews are one way that volunteer Judges get information about teams to determine winners of some awards at the event. An interview includes two or more judges, and is about a 5-10 minute conversation.
Judges interview teams in their pits.
Two judges seated at a table smile as they talk with two IQ team members.
Now it's time to make sure that your engineering notebook is ready for judging. In this activity, you will judge your own notebook, using the Student-Friendly Engineering Notebook Rubric, and make notes about what you want to change in your notebook moving forward.
Use this task card (Google doc / .pdf / .docx) to guide you through the activity.
  • Make sure that all team members are clear on what is in the engineering notebook.
  • Your notebook doesn't have to be perfect for your first competition. It will continue to grow and get better throughout the season. This activity will help you prepare for this competition, and think more about your notebook for the next one.
Select Next Session > to move on to the next session.
