1725399678
Skip to main content
Installing Rubber Shaft Collars
Rubber Shaft Collar held in a hand, demonstrating how to warm it for easier application onto a shaft. The diagram illustrates the process of softening the rubber by holding it for 15-30 seconds before use.
Using your hand to warm a Rubber Shaft Collar
Rubber Softens as it gets Warm
Hold the Rubber Shaft Collars in your hand for 15-30 seconds before you slide them onto a shaft. Holding the Rubber Shaft Collar in your hand will warm and soften the rubber to make it easier to slide onto a shaft.
