1725399110
Skip to main content
Changing the Velocity of Competition Robots
VEX IQ Robotics Competition team working on their robot's code beside the Practice Field, indicating the value of velocity control in a competition setting.
Changing the velocity is an important skill in competitions
Speed and Control
Competition robots are required to move through a course with precise and accurate movements. They also move, stack, or grab certain objects in order to be awarded points. Robots have to be able to properly change velocity in order to make more controlled movements. For example, if a robot is required to pick up an object, having the robot approach the object at its full velocity before picking it up will likely cause the robot to run into or over the object. It would be more beneficial for the robot to slow down in front of the object before picking it up.
Time is one of the biggest constraints in a competition match. The robot has to try to accumulate as many points as possible during the given time limit. To do this, the robot must move as fast as it can while still maintaining control. If the robot needs to move around a specific object, reducing the velocity allows the robot to have more control while turning. In order to move the robot forward or in reverse as fast as it can, the velocity must also be able to increase. The challenge in competition matches is finding the balance between having the robot move at a high velocity and control in order to obtain as many points as possible!
