1725399757
Skip to main content
Removing Standoffs from Mini Standoff Connectors
Diagram of a technique for removing a standoff from a Mini Standoff Connector, by pushing a shaft through the connector.
Removal of a standoff from a Mini Standoff Connector
How to Easily Remove Parts from Mini Standoff Connectors
Standoffs and Mini Standoff Connectors can be separated by pushing a shaft through the Mini Standoff Connector. The same technique can be used for parts with similar ends in Mini Standoff Connectors, such as pins.
