Skip to main content
Session 2
Now that you've been introduced to V5RC Push Back, it's time to build your first competition robot! Hero Bots are designed with different features and functions to help you get started with this year's game. In this session, your team will construct this year's Hero Bot, Dex.
Since Dex is a large build, the process is broken into stages. Everyone on the team will have a chance to build a part of Dex. When it's not your turn to build, you'll be practicing your skills in other areas as you rotate through four stations.The 2025-26 V5RC Hero Bot Dex.
Before you begin, make sure you have the following ready:
Get ready for building! You will use 3D Build Instructions to construct part of the Hero Bot, Dex with your partner. If you've never used 3D Build Instructions before, watch the video below to get started.
Use this task card (Google doc / .pdf / .docx) to guide you through what to do in this station.
Have fun building Dex!
It's time to hone your driving skills! You will take turns driving and scoring with Dex in Virtual Driving Skills Practice. This is your chance to learn more about the Hero Bot and its controls while you try to score points.
The V5RC Virtual Driving Skills Practice homepage showing the drive mode options and the field at the start of a Push Back match.
Have fun driving virtual Dex!
Now you're ready to test your coding skills with Dex! You will work with your partner to code Dex in V5RC Virtual Coding Skills in VEXcode VR. This is your chance to practice coding and scoring points with Dex. Watch this video to see how to get started with V5RC Push Back Virtual Skills.
  • Talk with your partner to make a plan before you begin to code.
  • You can access VEXcode VR at vr.vex.com.
  • Learn about the V5RC Push Back Playground, Dex, and every block in the Toolbox at api.vex.com.
Have fun coding Dex!
It's time to dive deeper into V5RC Push Back! You will watch the game unveil video again, this time looking for more game play specific and scoring details. Then you're going to ask and answer some questions to help get you thinking about the game and competition as a whole. This is your chance to get into the game so you can be ready to start strategizing when the time comes.
Watch the game unveil video below.
  • Take notes as you watch the video, and use them to help you answer the questions on the task card.
    • You can also use the game manual to help you answer your questions.
  • Talk with your partner to make sure that you're in agreement about your answers to each question.
Get excited about V5RC Push Back!
Now that you've got your Hero Bot ready to go, and you understand more about Robot Skills and Head to Head Matches, you're ready to dive into using Dex on the V5RC Push Back Field!
A robotics student adjusts motors on the underside of a competition robot, while two other team members hold the robot up. A controller sits on the table in front of them.
Select Next Session > to move on to the next session.
