Skip to main content
Session 2
Now that you've been introduced to Override, it's time to build your first competition robot! Hero Bots are designed with different features and functions to help you get started with this year's game. In this session, your team will construct this year's Hero Bot, Flex.
Since Flex is a large build, the process is broken into stages. Everyone on the team will have a chance to build a part of Flex. When it's not your turn to build, you'll be practicing your skills in other areas as you rotate through four stations.The 2026-2027 Hero Bot, Flex
Before you begin, make sure you have the following ready:
Get ready for building! You will use 3D Build Instructions to construct part of the Hero Bot, Flex with your partner. If you've never used 3D Build Instructions before, watch the video below to get started.
Use this task card (Google doc / .pdf / .docx) to guide you through what to do in this station.
Have fun building Flex!
It's time to hone your driving skills! You will take turns driving and scoring with Flex in Virtual Driving Skills Practice. This is your chance to learn more about the Hero Bot and its controls while you try to score points.
Screenshot of the VEX V5 Robotics Competition Override Virtual Driving Skills Practice app, showing connection status, drive mode selection (Tank Drive selected), and an overhead view of the game field with a robot, Pins, Cups, Toggles, and a Score, timer, and Match Loads panel.
Have fun driving virtual Flex!
Now you're ready to test your coding skills with Flex! You will work with your partner to code Flex in VEX V5 Virtual Coding Skills in VEXcode VR. This is your chance to practice coding and scoring points with a virtual version of Flex. Watch this video to see how to get started.
  • Talk with your partner to make a plan before you begin to code.
  • You can access the VEX V5 Override Playground at vrskills.vex.com, or through VEXcode VR.
  • Learn about the VEX V5 Override Playground, Flex, and every block in the Toolbox at api.vex.com.
Have fun coding Flex!
It's time to dive deeper into VEX V5 Override! You will watch the game unveil video again, this time looking for game play specific and scoring details. Then you're going to ask and answer some questions to help get you thinking about the game and competition as a whole. This is your chance to get into the game so you can be ready to start strategizing when the time comes.
Watch the game unveil video below.
  • Take notes as you watch the video, and use them to help you answer the questions on the task card.
    • You can also use the game manual to help you answer your questions.
  • Talk with your partner to make sure that you're in agreement about your answers to each question.
Get excited about V5 Override!
Now that you've got your Hero Bot ready to go, and you understand more about Robot Skills and Head to Head Matches, you're ready to dive into using Flex on the V5 Override Field!
A V5 Robot on a table in between two girls. One is adjusting something on the robot with a screwdriver while the other holds a piece in place.
Select Next Session > to move on to the next session.
