1730758662
Skip to main content
Programming Drive Forward and Reverse - C++
The Speedbot is ready to move!
This exploration will give you the tools to be able to program your Speedbot for simple movements. At the end of this activity, you will engage in the Basketball Drills Challenge using forward, reverse, and waiting behaviors.
  • VEXcode V5 instructions that will be used in this exploration:
    • Drivetrain.driveFor(1, inches);
    • wait(1, seconds);
  • To find out more information about the instruction, select Help and then select the question mark icon next to a command to see more information.
    Image of the VEXcode V5 Workspace with help notes open for the Drivetrain Drive For command
  • Make sure you have the hardware required, your engineering notebook, and VEXcode V5 downloaded and ready.
Materials Required:
Quantity Materials Needed
1
Speedbot Robot
1
Charged Robot Battery
1
VEXcode V5
1
USB Cable (if using a computer)
1
Engineering Notebook
Step 1:  Preparing for the Exploration
Before you begin the activity, do you have each of these items ready? Check each of the following:
Step 2:  Start a New Project
Complete the following steps to begin the project:
  • Open the File menu and select Open Examples.
    VEXcode V5 Toolbar with the File menu open and Open Examples highlighted in a red box. Open Examples is the fourth menu item beneath New Blocks Project, New Text Project, and Open.
  • Select and open the Speedbot (Drivetrain 2-motor, No Gyro) template project. The template project contains the Speedbot's motor configuration. If the template is not used, your robot will not run the project correctly.
    Image showing the Example projects with a red box around the Speedbot (Drivetrain 2-motor, No Gyro) Template Project
  • Since you will be working on moving the Speedbot forward and reverse, you will name your project Drive. Select the Project Name, Type in 'Drive' and then select 'Save.'
Image showing the project name being changed to drive
  • Check to make sure the project name Drive is now in the window in the center of the toolbar.
    Project name changed to drive in the Toolbar.
Step 3:  Drive Forward
You are now ready to begin programming the robot to drive forward!
  • Before we begin programming, we need to understand what an instruction is. There are three parts to an instruction. For more information on what an instruction is, view this article.
    A C++ command broken down into its components. Drivetrain is labeled as the device; Drive for is labeled as the commands; and forward, 100, and mm are labeled collectively as parameters.
  • Add the instruction to the project, so that your project looks like this:
    int main() {
      // Initializing Robot Configuration. DO NOT REMOVE!
      vexcodeInit();
      // Begin project code
      Drivetrain.driveFor(forward, 100, mm);
  • Select the Slot icon to choose one of the eight available slots on the Robot Brain and select slot 1.
    VEXcode V5 Toolbar with the Slot menu opened to the left of the project name. The dropdown menu lists all of the available slots, from 1 to 8. The first slot is highlighted with a red box.
  • Connect the V5 Robot Brain to the computer using a micro USB cable and power on the V5 Robot Brain. The Brain icon in the toolbar turns green once a successful connection has been made.
    Toolbar in VEXcode V5 with a red box around the green Brain icon, located between the Controller and Download icons.
  • Select Download to download the project to the Brain.
    Toolbar in VEXcode EXP with a red box around the download icon, located between a greed Brain icon and the Run and Stop buttons.
  • Check to make sure your project has downloaded by looking at the Robot Brain’s screen. The project name Drive should be listed in Slot 1.
    V5 Brain Home Screen shows the Drive program in slot 1 in the lower left corner directly beneath the Drive icon.
  • Run (C++) the project on the robot by making sure the project is selected and then press the Run button on the Robot Brain. Congratulations on creating your first project!
    V5 Brain screen with the Drive program open and a red box around the Run button on the far left side. To the right of Run are buttons for Timed Run, Match, and Wiring.
Step 4:  Drive Reverse
Now that you have programmed your robot to drive forward, let us program it to now drive in reverse.
  • Change the parameter in the drive instruction to reverse, so your project looks like this:
    int main() {
      vexcodeInit();
  • Select the Project Name to change it from Drive to Reverse.
    Project name in the Toolbar reads Reverse and slot 1 is selected.
  • Select the Slot icon to choose a new slot. Select slot 2.
    Slot selection in VEXcode V5 open with slot 2 selected and highlighted with a red box.
  • Download (in C++) the project.
    VEXcode V5 Toolbar with the Download button highlighted by a red box on the right side. The Download button is located to the right of a green Brain icon and to the left of the Run and Stop buttons.
  • Check to make sure your project has downloaded (in C++) by looking at the Robot Brain’s screen. The project name Reverse should be listed in Slot 2.
    V5 Brain Home Screen shows the Reverse project in Slot 2, the second icon from the left in the bottom row, beside the Drive project in Slot 1.
  • Run (in C++) the project on the robot by making sure the project is selected and then press the Run button on the Robot Brain.
    V5 Brain Screen with the Reverse project open and the Run button highlighted in a red box to the far left. To the right of Run are buttons for Timed Run, Match, and Wiring.
Step 5:  Wait then Drive in Reverse
Now that we have programmed the robot to drive forward and then in reverse, we can now add a wait instruction so that the robot waits a certain amount of time before driving in reverse.
  • Add a Wait instruction before the Drive for command. Be sure the Wait is indented to match the Drive for command, and that all commands are within the curly braces. This tells the robot to wait three seconds before driving in reverse.
        wait(3, seconds);
  • Select the Project Name to change it from Reverse to WaitReverse.
    Project name changed to Wait Reverse in the Toolbar, and slot 2 is selected.
  • Select the Slot icon to choose a new slot. Select slot 3.
    Slot selection in VEXcode V5 with a red box around Slot 3 of 8.
    Download button in the VEXcode V5 Toolbar highlighted with a red box around it, between the green Brain icon and the Run and Stop buttons.
  • Check to make sure your project has downloaded (in C++) by looking at the Robot Brain’s screen. The project name WaitReverse should be listed in Slot 3.
    V5 Brain Home screen shows the Wait Reverse project in slot 3, the third icon in the bottom row.
  • Run (in C++) the project on the robot by making sure the project is selected and then press the Run button.
    V5 Brain screen with the Wait Reverse project open and the Run button highlighted in a red box to the far left. To the right of Run are buttons for Timed Run, Match, and Wiring.
Step 6:  Complete the Basketball Drills Challenge!
Setup for Basketball Drills shows four lines spaced out with a start line on the left, and lines at 10cm, 20cm, and 40cm away. A V5 Robot sits ready to begin with its front wheels on the start line.
Basketball Drills Challenge layout
In the Basketball Drills Challenge, the robot must be able to navigate a series of lines at different distances. The robot will travel forward to the first line which is 10 cm from the starting position, wait 1 second, and then travel backwards returning to that same line. The robot will then repeat the action by driving forward 20 cm to the second line, wait 1 second, and then drive backward to the original starting line. The robot will drive forward to the third line with a distance of 40 cm, wait 1 second, and then finally return to the starting line to finish the challenge.
Before programming the robot, plan out the robot's path and behaviors in your engineering notebook.
After completing the Basketball Challenge, you will be able to combine forward and reverse movements with additional robot behaviors to complete even more advanced challenges.
Keep in mind when programming that 1 cm = 10 mm.
