Skip to main content
Adding the Vision Sensor
After the V5 Clawbot has been assembled, use the building instructions below to add the Vision Sensor.
Step 1 of the build instructions showing how to attach a gusset to the Vision Sensor with screws.Step 2 of the build instructions showing how to screw a standoff into the bottom hole of the standoff, once connected to the Vision Sensor.Step 3 of the build instructions showing how to connect the Vision Sensor with a screw to the top of the arm of the Clawbot.Step 4 of the build instructions indicating to plug a 600mm smart cable from the Vision Sensor to port 5 on the Brain.
