Create a Boolean Variable
Now that the goals of the project have been outlined using comments, the Boolean variable block must now be created.
To create a Boolean variable, select the ‘Variables’ category in the Toolbox and then select ‘Make a Boolean.’
Note: for more information about variables, view the Storing Data tutorial video in VEXcode V5.
Name the variable ‘greenDisk,’ then select ‘Submit.’
Note: for more information about naming rules for variables view the Name Rules for Variable and Device article from the Knowledge Base.
The variable ‘greenDisk’ will now appear in the ‘Variables’ category in the Toolbar.
Select and drag the [Set Boolean variable] block from the ‘Variables’ category in the Toolbox and attach it to the ‘Create Boolean variable to track green disks’ [comment] block. Set the parameter to ‘false,’ since the first disk will need to be placed, and will not have been placed yet.
