Skip to main content
Testing the Disk Feeder
Now that the Disk Feeder has been added, speed of the Entry Conveyor needs to be tested and adjusted to ensure that it dispenses a disk correctly from the Disk Feeder.
Loaded Feeder
Once a disk has been loaded onto the Transport Conveyor, the conveyor should stop once the green disk is detected by the Load Sensor.
Load Sensor Callout
  1. Add a [Stop motor] block to the [Wait until] block and set the motor to ‘TransportMotor.’
    Set to TransportMotor
  2. Load a green disk into the Disk Feeder.
    Green Feed
  3. Download and run the project.
    Download and run
  4. Observe the green disk being dispensed from the Disk Feeder onto the Transport Conveyor.
    Green Feeder travel
  5. Stop the project.
    Stop the project
  6. Note that the Entry Conveyor spun slightly too fast for the disk to be dispensed properly. Adjust the velocity of the Entry Motor to 30%.
    Adjust velocity to 30
    Note: the velocity can be adjusted to a different parameter other than 30%. Test different variations to determine which velocity is best for your Workcell.
  7. Adjust the time in seconds that the Entry Conveyor runs. Change the parameter of the [Wait] block to 1.5 seconds.
    Wait block
    Note: the time can be adjusted to a different parameter other than 1.5 seconds. Test different variations to determine which time is best for your Workcell.
  8. Load a green disk into the Disk Feeder.
    Green Feeder
  9. Download and run the project.
    Download and run
  10. Observe the green disk being dispensed from the Disk Feeder onto the Transport Conveyor and stop when the Load Sensor detects the disk.
    Sensor Callout Green
  11. Stop the project.
    Stop the project
  12. Continue to adjust and test the parameters of the Entry Motor velocity and the [Wait] block as needed to best dispense a disk from the Disk Feeder onto the Transport Conveyor. Once the parameters are finalized, remove the [Stop motor] block from the project.
    Remove block
