Skip to main content
Create the Triangles Project
  1. Remove the cap from the dry-erase marker. Six points will be drawn to outline two triangles. Each triangle will be outlined with three points. Draw these six points on the whiteboard using the dry-erase marker. The exact location of the points may vary, but should be far enough apart to view lines between them.
    Triangle top down view
  2. Attach the dry-erase marker to the arm mounted on the VEX V5 Workcell if you have not done so already.
    Pen Calllout
  3. Launch VEXcode V5.
    VEXcodeV5-icon
  4. Open the ‘Lab 3- Display Position’ project from a previous Lab.
    Lab 3 Display Position (1)
  5. To save and rename the project for Lab 6, select ‘File’ and then ‘Save As’ from the Toolbar in VEXcode V5.
    File Save As
  6. Name the project ‘Lab 6- Triangles.’
    Lab 6 Triangles
    Note: for more information about saving, view the Save a Blocks Project (Chromebook, Windows, macOS) articles.
  7. The Toolbar will now display the project as ‘Saved.’ Any subsequent changes to the project will be automatically saved.
    Lab 6 triangles title
  8. Set the parameter of the [Set tool] block to ‘marker.’
    Set tool to marker
