Compete
Now that you have practiced using the different wheel combinations on your BaseBot, it is time to complete the Figure Eight Wheel Challenge.
In this video, a BaseBot is placed on the left side of the Field with a red and a blue Bucky Ball placed towards the right of the BaseBot on the field. The BaseBot then drives in a figure eight pattern around the Bucky Balls to complete the challenge.
Follow the steps in this document to play the Figure Eight Wheel Challenge.
Google Doc / .docx / .pdf
Once you have completed Figure Eight Wheel Challenge, check in with your teacher. Ensure you have documented the results of the challenge in your engineering notebook.
Wrap Up Reflection
Now that you have tested the different wheel types and completed the challenge, it is time to reflect on what you have learned and done in this Lesson. Start a new page in your engineering notebook to begin your reflection.
Rate yourself as a novice, apprentice, or expert on each of the following concepts in your engineering notebook. Provide a brief explanation for why you gave yourself that rating for each concept:
- The differences between the three types of wheels
- Testing different wheel combinations in order to get the fastest time in the challenge
- Problem-solving with your group to change and test different wheel combinations on your BaseBot
Use this table to help you determine which category you fall under.
Expert | I feel that I fully understood the concept and could teach this to someone else. |
Apprentice | I feel that I understood the concept enough to compete in the challenge. |
Novice | I feel that I did not understand the concept and did not know how to complete the challenge. |
What is Next?
In this Lesson, you experimented with different wheel combinations to improve your time in the Figure Eight Wheel Challenge.
In the next Lesson, you will:
- Add a Bumper Switch to your robot.
- Configure the Bumper Switch and the Controller in VEXcode EXP.
- Print to the Brain Screen in VEXcode EXP.
- Compete in a One-on-One Freeze Tag Challenge!
Select < Return to Lessons to go back to the Lesson Overview
Select Next > to continue to Lesson 4, and learn about adding the Bumper Switch to your robot, and how to print to the Brain's screen.
