Skip to main content
Design, Develop, and Iterate on your Project
Follow the steps below as you create your project:
  1. Plan out the path you want to program your robot to take using drawings and pseudocode (Google Doc / .docx / .pdf).
  2. Use the pseudocode you created in the Play section to develop your project using blocks.
  3. Test your project often and iterate on it using what you learned from your testing.
If you're having trouble getting started, review the Example Projects below within VEXcode IQ:
  • Forward (Inches or mm)
  • Backward (Inches or mm)
  • Left Turn (Degrees)
  • Right Turn (Degrees)
  • Claw and Arm
  • Use the Claw
  • Use the Arm
VEXcode IQ Toolbar with the File menu open, and Open Examples selected with a cursor. 'Open Examples' is the fourth item in the menu.
