Programming Loops - Python
Teacher Toolbox
Activity Outline
This exploration will introduce students to programming repetitive behaviors by using repeat or forever loops.
Learning to program using repeat and forever loops allows students to save time when building a project that uses the same repeated actions. For more information about the instructions used in a text project, visit the help information.
The Clawbot V5 is ready to move!
This exploration will give you the tools to be able to start creating some cool projects that use loops.
- VEXcode V5 Python instructions that will be used in this exploration:
- drivetrain.drive_for(FORWARD, 300, MM)
- drivetrain.turn_for(RIGHT, 90, DEGREES)
- claw_motor.spin_for(REVERSE, 70, DEGREES)
- arm_motor.spin_for(FORWARD, 360, DEGREES)
- bumper_b.pressing()
- while True:
- for repeat_count in range(4):
- wait(5, SECONDS)
You can use the Help information inside of VEXcode V5 to learn about individual Python commands.
Teacher Tips
If this is the student's first time using VEXcode V5, they can read a variety of articles in the VEX Library.
Teacher Tips
Using Autocomplete
Autocomplete is a feature in VEXcode V5 that predicts the rest of the command you are typing. As students are working in VEXcode V5, encourage them to use the Autocomplete feature to help with the Python syntax. You may notice an autocomplete function as you start to type the instruction. Use your “Up” and “Down” keys to select the name you want, then press “Tab'' or (Enter/Return) on your keyboard to make the selection. For more information on using Autocomplete check out the Python article.
Make sure you have the hardware required, your engineering notebook, and VEXcode V5 downloaded and ready.
| Quantity | Materials Needed |
| 1 |
VEX V5 Classroom Starter Kit (with up-to-date firmware) |
| 1 |
VEXcode V5 (latest version, Windows, macOS) |
| 1 |
Engineering Notebook |
| 1 |
Clawbot Template (Drivetrain 2-motor, No Gyro) example project |
Step 1: Let's start programming with loops
- Before you begin your project, select the correct template project. The Clawbot Template (Drivetrain 2-motor, No Gyro) example project contains the Clawbot's motor configuration. If the template is not used, your robot will not run the project correctly.
Select File and Open Examples.
Scroll through the different Example projects. These projects demonstrate a variety of actions your Clawbot can perform. Select and open the Clawbot Template (Drivetrain 2-motor, No Gyro) example project.
Name the project RepeatingActions.
Type the following code:
# Library imports from vex import * # Begin project code # Drives forward 300mm turns 90 degrees for 4 iterations for repeat_count in range(4): drivetrain.drive_for(FORWARD, 300, MM) drivetrain.turn_for(RIGHT, 90, DEGREES) wait(5, SECONDS)
Look over the project and then do the following in your engineering notebook.
Predict what the project will have the Clawbot do. Explain more than the fact that the project repeats.
What is it repeating? What is the Clawbot doing?
- Write your prediction, but do not break the short project into more than two parts.
Teacher Toolbox
Answers
This project will have the robot: drive forward for 300 millimeters , turn right 90 degrees, and then wait for 5 seconds 4 times to complete a square. Instead of using the same 3 instructions 4 times, the repeat instruction reduces the amount that to just 1 time. The repeat instruction repeats the actions of driving forward and then turning.
The prediction might simply be "The Clawbot moves in a square." This would be a succinct way to capture the repeated movements of the Clawbot while lacking any context.
Students' engineering notebooks can be maintained and scored individually or as a team. The previous links provide a different rubric for each approach. Whenever a rubric is included in educational planning, it is good practice to explain the rubric or at least give copies to students before the activity begins.
Save, download, and run the Repeating Actions project.
- Check your explanations of the project in your engineering notebook and add notes to correct them as needed.
Step 2: Run the project and observe the robot
Look at the Repeating Actions project (the second project) again. This project will repeat the forward and then turn behavior four times. A "repeat" loop structure (using a for loop) is used when you want to use a set of behaviors a certain number of times.
If the repeat structure is replaced with a while loop structure, the robot will repeat the forward and then turn behaviors "while" the condition is true. You can also set the condition to "true" to have the while loop continue forever.
In the first project, a sensor's input is used to determine when to begin turning. The project on the right uses a fixed Drivetrain distance to determine when to begin turning.
In order to continually check a sensor's input, an if else statement is used together a while loop. In the project on left, the robot will turn right when the "bumper_b" sensor is pressed, otherwise the robot will drive forward forever if the "bumper_b" sensor is not pressed. To continually check the bumper_b sensor's value, the if statement is within a while loop.
The first project is a practical use-case of a structure that repeats forever – using while loops and if statements together. Imagine a self-driving sweeper that continues to drive forward until it runs into a wall or object, then turns before continuing to drive.
Extend Your Learning
To further explore how you can use loops with conditionals, have the students build a Floor Sweeper project in VEXcode V5.
- Begin by having the students mount and wire the bumper switches.
Ask students to open the Clawbot Template (Drivetrain 2-motor, No Gyro) example project.
- Have the students configure the 3-Wire Bumper Switch in VEXcode V5, select the 3-wire Device that you are using to BUMPER, and select the port to B.
Have the students name the project as Floor Sweeper.
Ask students to build the following project.
# Library imports from vex import * import random # Begin project code while True: while (not bumper_b.pressing()): drivetrain.drive(FORWARD) wait(5, MSEC) drivetrain.stop() #The random.randomint() method returns a random integer number between the specified range #Pass the min and max values of the range to the parameters drivetrain.turn_for(RIGHT, (90+random.randint(0, 90)),DEGREES) wait(5, MSEC)
If the students need help with any of the instructions, refer them to the Help information.
Ask the students to download and run the project to observe how the robot moves. Then, begin a class discussion and ask the students to explain why the forever structure was used instead of a repeat structure.
The students should note that a forever structure is used because this project continuously checks to see if the bumper switch is being pressed.
Step 3: The Squared Loops Challenge!
- Have your Clawbot drive in a square.
- Before each turn, the claw must be opened and closed, and the arm must be raised and lowered.
- The Clawbot cannot drive along a side of the square more than once.
- You can use the RepeatingActions project from above as a starting point but save it as SquaredLoops before making any changes.
In your engineering notebook, plan the following:
- Plan out your solution and predict what each instruction in your project will have the Clawbot do.
- Download and run your project to test it before submitting it.
- Make changes to the project as needed and take notes about what was changed during testing.
Teacher Toolbox
Solution
The following is a potential solution to the Squared Loops Challenge:
# Library imports
from vex import *
claw_motor.spin_for(FORWARD, 70, DEGREES)
arm_motor.spin_for(REVERSE, 360, DEGREES)
wait(5, MSEC)You can provide students with a programming rubric for scoring their projects.
