The Groove Machine Challenge - Python
In this challenge, you will break up into teams and program your robot to go through a dance routine using your knowledge of loops. Your teacher will set a time limit for developing/testing the dance and a time limit for the length of the dance. Everyone not on the competing head-to-head dance-off teams will judge the dances and vote on the team that they think is best.
Rules:
- Each Clawbot will dance one-at-a-time within the 1x1 meter area.
- The dancing continues until the Stop button on the Brain's screen is pressed to stop the project from running.
- The arm must be raised and lowered.
- The claw must open and close.
- The Clawbot must turn left and right.
- The Clawbot must drive forward and in reverse.
- The project needs to be stopped immediately if the Clawbot collides with anything or falls over. That is a losing dance.
Teacher Toolbox
Judging for this competition could be handled in a number of ways. One way to increase engagement is to have students video record the dance-off and have students from other classes vote on the winner. If that is too ambitious, consider appointing a panel of impartial judges before beginning this challenge, or bringing in other students, teachers, or staff.
The solution below is merely a combination of all three example dance moves strung together.
# Library imports
from vex import *
# Begin project code
while True:
arm_motor.spin_for(FORWARD, 300, DEGREES)
arm_motor.set_stopping(BRAKE)
for repeat_count in range(3):
drivetrain.turn_for(RIGHT, 90, DEGREES)
for repeat_claw in range(2):
claw_motor.spin_for(REVERSE, 90, DEGREES)
claw_motor.spin_for(FORWARD, 90, DEGREES)
wait(5, MSEC)
drivetrain.turn_for(LEFT, 90, DEGREES)
wait(5, MSEC)
wait(5, MSEC)
for repeat_count in range(2):
for repeat_turn in range(9):
drivetrain.turn_for(LEFT, 10, DEGREES)
wait(5, MSEC)
arm_motor.spin_for(REVERSE, 300, DEGREES)
wait(5, MSEC)
arm_motor.set_velocity(80, PERCENT)
drivetrain.set_turn_velocity(65, PERCENT)
for repeat_turn in range(3):
wait(5, MSEC)
wait(5, MSEC)
