Skip to main content
Programming with Conditionals - C++
The Clawbot is ready to make decisions!
This exploration will give you the tools to be able to start creating some cool projects that use if then else statement.
  • VEXcode V5 C++ commands that will be used in this exploration:
    • Drivetrain.drive(forward);
    • Brain.Screen.pressing()
    • Drivetrain.stop();
    • if (condition){}
    • waitUntil();
    • while (condition){}
    • wait(1, seconds);
You can use the Help information inside of VEXcode V5 to learn about the C++ instructions.
VEXcode V5 with a drive for command typed in the workspace on the left, and the Help information open on the right. The Help shows a definition of the command and information about how it is used.
Make sure you have the hardware required, your engineering notebook, and VEXcode V5 ready.
Materials Required:
Quantity Materials Needed
1
VEX V5 Classroom Starter Kit (with up-to-date firmware)
1
VEXcode V5 (latest version, Windows, macOS)
1
Engineering Notebook
1
Clawbot (Drivetrain 2-motor, No Gyro) Template
Step 1: Let's start with an understanding of conditional statements
Before you begin programming with conditionals, read the VEX Library Article explaining If Then Else Statements. The article can be found here.
Screenshot from the VEX Library, showing an article titled Using if-else statements in VEXcode V5.For a list of operators to use in the If Then Else statements, read the VEX Library Article explaining Booleans. This article can be found here.Screenshot from the VEX Library, showing an article titled Using Booleans in VEXcode V5.
Step 2: Let's start programming with conditional statements.
  • Open the Clawbot (Drivetrain 2-motor, No Gyro) template example project.
    Example project selection in VEXcode V5 with a red box around the Templates filter at the top and the Clawbot drivetrain 2 motor no gyro project, indicating which template to open.
  • Build the project below.
// Begin project code
int main() {
  // Initializing Robot Configuration. DO NOT REMOVE!
  vexcodeInit();
  while (true) {
    if (Brain.Screen.pressing()) {
      Drivetrain.stop();
      waitUntil(!Brain.Screen.pressing());
Do the following in your engineering notebook:
  • Explain what the project has the Clawbot do. You will need to explain more than the fact that it creates a stop button. Explain which instructions make the Clawbot do what.
  • Write a one sentence summary that captures what the project does.
  • Test to see if your prediction of what the project has the Clawbot do is correct.
Project Name Dialog box in the VEXcode V5 Toolbar reads Creating a Stop Button and shows that slot 1 is selected.
  • Save and download the project as CreatingAStopButton to Slot 1 on the Clawbot, and then run it.
  • For help downloading a project, see the tutorial in VEXcode V5 that explains how to Download and Run a Project (C++).
  • Check your explanations of the project and add notes to correct them as needed.
Step 3: Understanding the wait until() statement.
Notice that if the Brain's screen is pressed, the flow of the project moves quickly and the project will move to the next instruction, which is the Drivetrain.stop() instruction.
Thus, the project needs a waitUntil() instruction that tells the robot to remain stopped until the Brain's screen is released. Otherwise, the forever statement would cause the project to begin again.
The waitUntil() instruction is necessary because of the speed of the project's flow. If it was not there, the project would move to the next instruction before the robot ever had time to respond.
Step 4: Change the project.
Our next step is changing the if then statement to an if then else statement.
Project name dialog box in the VEXcode V5 Toolbar reads Stop or Drive and shows that slot 1 is selected.
  • Start by saving CreatingAStopButton as the new project, StopOrDrive.
  • If you need help saving a project, click here for C++.
  • Then build the StopOrDrive project shown below.
int main() {
  vexcodeInit();
  while (true) {
      Drivetrain.stop();
    else {
  • Download StopOrDrive to Slot 2 on your Clawbot.
Slot selection in the VEXcode V5 Toolbar is open and slot 2 is selected and highlighted with a red box. The project name reads Stop or Drive.
  • Test CreatingAStopButton (Slot 1) and then test StopOrDrive (Slot 2) and compare them to see if there are any difference in the robot's behavior. Note any differences in your engineering notebook
The two projects have the Clawbot behave the same way. The only difference is the use of the if then else statement in the StopOrDrive project.
Using the if then else statement will allow you to add additional buttons to the screen in upcoming activities.
