Check Your Understanding
Teacher Toolbox
- Which of the following best describes the difference between linear and joint movement of the arm on the Workcell?
The arm moves in a straight line during linear movement and moves in an arc during joint movement. - Which of the following is the controller for the Workcell?
The V5 Brain - Which of the following is the best description of joint movement?
The robot’s path follows the shortest possible arc between two known points. - Which type of movement is depicted in this image?
Joint movement - Which type of movement is depicted in this image?
Linear movement
Quiz
