Skip to main content
Answer Key
Summative Assessment Answer Key
  1. Which of these is best described as “an ordered group of stored values?”
    2D List
  2. How many rows does this 2D List have?
    8
  3. How do you pick the marker up off of the whiteboard on the Workcell using the arm mounted on the VEX V5 Workcell?
    Add a coordinate point with a higher z-coordinate value.
  4. How many times will the [Repeat] block iterate in this project?
    10 times
  5. If you wanted to only draw the second triangle, what would you set the “waypointindex” to in this project?
    6
