Skip to main content
Lesson 3: Mini Challenge
For this mini challenge, create a project where the VR Robot picks up and drops each of the blue disks into the blue goal on the Disk Mover Playground. Use the [Energize Electromagnet], [Repeat until], and sensing blocks to instruct the VR Robot to drive up to each blue disk, pick up the disk, drive back to the start, and drop the disk in the blue goal.
All 3 blue disks
Follow these steps to complete the mini challenge:
  • Watch the solution video to see how the VR Robot should drive in order to complete the mini challenge.
  • Create a project by adding or removing the necessary blocks to the Unit8Lesson3 project.
  • Start the project to test it.
  • If the project is not successful, edit and try again. Continue to revise and run the project until the VR Robot successfully picks up and drops each of the blue disks into the blue goal on the Disk Mover Playground.
  • Save the project once the VR Robot successfully picks up and drops each of the blue disks into the blue goal on the Disk Mover Playground.
Questions
Please select the link below to access the lesson quiz.
Open Lesson Quiz   >
