Skip to main content
Practice
In the last section, you learned about the Bumper Switch, how to print to the Brain screen, and how to assign the Drivetrain to the Controller's Joysticks. Now, you are going to apply what you have learned in the Bumper Press Practice Activity.
In this activity, you will practice your driver skills to navigate between plates mounted on the Field, but with the Bumper Switch added. If you accidentally back into a plate or the wall, your Controller will be disabled and your Brain screen will turn red.
Watch the video below to find out more about the Bumper Press Practice Activity.
Now it's your turn to complete the Bumper Press Practice Activity!
In this video, a BaseBot is placed in the bottom-left corner of the Field. There are three 4x16 plates with brackets on the Field: one in the second row, second column; another in the third row, third column; and the last in the second row, fourth column. The BaseBot first drives below the first plate from left to right at a slight angle, then drives above the second plate and under the third plate. When it reaches the right side of the Field, it backs into the third plate, causing it to freeze with its brain turning red. After three seconds, the BaseBot turns green and drives back to the left side of the Field, below the first plate, and stops at the bottom-left corner where it started.
Follow the steps in this document to complete this activity. Google Doc / .docx / .pdf
As your team completes the Bumper Press Practice Activity, document your findings in your engineering notebook. Think about how quickly and successfully each driver was able to navigate through the plates on the Field, as this will help you select a driver for upcoming challenges.
View this image for an example of how you can record your results.
Notebook page titled Freeze Tag - Bumper with a table noting the Team, Time, and Bumper Pressed. Data for Jane, John, and Alex is recorded and beneath the table are additional notes represented by squiggly lines.
Prepare for the Challenge
In Compete (on the next page), you will compete in the One-on-One Freeze Tag Challenge. Learn how to compete in the challenge, check your understanding, then practice for the challenge.
In this video, the BaseBot on the left presses the Bumper Switch of the BaseBot on the right, causing it to freeze and stop driving, while the Brain turns red. While the second robot is frozen, the first robot drives away, demonstrating how one robot can tag another in the One-on-One Freeze Tag Challenge.
Follow the steps in this document to learn more about how to complete this activity.
Check Your Understanding
Before beginning to compete in the One-on-One Freeze Tag Challenge, ensure that you understand the rules and set up of the activity by answering the questions in the document below in your engineering notebook.
Check Your Understanding questions Google Doc / .docx / .pdf
After completing the questions, try practicing the One-on-One Freeze Tag Challenge.
Select Next >  to compete in the One-on-One Freeze Tag Challenge.
