Engage
Launch the Engage Section
ACTS is what the teacher will do and ASKS is how the teacher will facilitate.
| ACTS | ASKS |
Facilitate the Build
InstructInstruct
students to join their group, and complete the Robotics Roles & Routines sheet. Use the Suggested Role Responsibilities slides in the Lab 5 Image Slideshow as a guide for students to complete this sheet.
Instruct students that the competition Hero Robot is built in two stages. First, they will build the Competition Base 2.0, then they will add onto that to build the Competition Advanced 2.0 Hero Robot. -
DistributeDistribute
build instructions for the Competition Bas. 2.0e to each team. Journalists should gather the materials on the checklist for the Competition Base 2.0 to begin.
Competition Base 2.0 As students complete the Competition Base 2.0, have them check in with you. Then, distribute build instructions for the Competition Advanced 2.0 Hero Robot. Students will add onto the Competition Base 2.0 to build the Competition Advanced 2.0 Hero Robot. Journalists should gather the materials on the checklist.
Competition Advanced 2.0 Hero Robot -
FacilitateFacilitate
the building process
- Builders and Journalists should begin building based on their responsibilities in the Lab 5 Image Slideshow.
- Depending on the amount of time you have, you may want to have students build the Competition Base 2.0, then stop, and resume building during the next class time.
- Circulate around the room to help students with building or reading instructions where needed. Remind students that they can orient the pieces they are holding and building with the same way they are shown in the build instructions, in order to help them be successful in their build.
- Engage students' prior knowledge by asking questions about how this build is similar or different to other VEX GO builds that they have used before, like the Code Base. Why do they think that is? What might the competition robot be able to do that is new or different?
- OfferOffer positive reinforcement for teams that are working well together, taking turns, and using respectful language as they are building. If there are particular teams or students that excel at building, offer them the opportunity to help teams that may be struggling with the build.
Teacher Troubleshooting
- Students can test that their Competition Base 2.0 is built correctly before moving on to the Competition Advanced portion of the build. Have them power on the Brain, connect to VEXcode GO and open the Drive tab. Use the joysticks to move the robot forward or backward. If the robot is built correctly, it should drive successfully when it is connected to VEXcode GO.
- Remind students that forward/reverse is based on the location and position of the robot. If the Hero Robot is backwards on the Field with the fork facing the student, moving the controls forward will drive the robot towards the student, not towards the Field.
- If the robot does not respond, try disconnecting and reconnecting the Brain and try again. This may happen if too much time passes between turns driving the robot.
Facilitation Strategies
- Allow time during Play Part 1 for all students to take a turn driving the Hero Robot on the Field. Remind students that they can change the controls to find a Drive Mode that works best for them.
- While practicing, teams may come across different disputes about strategy ideas. Use the prompts from the Background Information section on collaborative decision making to help facilitate production conversations with teams.
- You may want to allow extra time and VEX GO Kit pieces for students to design and build an iteration of the forks on the Hero Robot, to help them manipulate the opening the clam and obtaining the pearl more easily. You can use the Engineering Design Process Organizer to help students document the problem they are trying to solve, their design idea, and how successfully it accomplished their goal.
- To help students stay focused and organized, you may want to have them check in with you to share their design ideas before they begin building. This way, you can help them evaluate the feasibility of the iteration in the time and constraints of your setting. Ask questions like:
- How will this change help your robot move objects on the Field more easily? What problem are you having now that this iteration will solve?
- How much time do you think this will take you to build? Can you build it in the time we have in class?
- How will you test your iteration to know if it is successful? What will you look for in your next practice drive to know if it is working?
- You can offer constraints like the number of pieces, or the area of the robot that they can adapt, to help students focus on a small and specific iteration, rather than trying to redesign the entire arm.
- The speed of the Hero Robot depends on how slow or quickly the controls are moved in the Drive tab. The slower the joystick is pushed, the slower the robot will move. For more information about remote control driving in VEXcode GO, read the Using the Drive Tab in VEXcode GO article.
- Think ahead about how you want to structure the Ocean Science Exploration competition. It is recommended for each team to have at least two matches to compete in, so that as many students as possible get to have the chance to be a driver in the competition. To learn more about running VEX GO classroom competitions, see this article.
- Encourage students to document their learning by drawing or writing about their robot, driving practice, and competition strategy. Use the Blueprint Worksheet or the Data Collection Sheet as a basic template for students to take notes. These artifacts can then be used to share student learning and progress with others in the classroom and school community on a bulletin board or student portfolio.
