Skip to main content
What You'll Need to Know - C++
In order to successfully complete this STEM Lab, you'll need to know how to program the robot to move forward, in reverse, left and right before getting started. You can use the links to other STEM Labs below or the Example Projects in VEXcode V5 to learn how to drive and turn the robot before proceeding.
Basic Movements
VEXcode V5 Toolbar with the File menu open and Open Examples highlighted with a red box. Open examples is the fourth item in the menu beneath New Blocks Project, New Text Project and Open.
If you have not programmed your robot to drive or turn before, make sure to complete each with your robot before moving on!
