Skip to main content
Programming the Robot Arm - Python
The V5 Clawbot is ready to reach!
This exploration will give you the tools to be able to start creating some cool projects that use the V5 Clawbot's arm.
  • VEXcode V5 Python instructions that will be used in this exploration:
    • arm_motor.spin_for(FORWARD, 90, DEGREES)
    • arm_motor.set_position(0, DEGREES)
    • wait(2, SECONDS)
  • To find out more information about the instruction, select the question mark icon next to a command to see more information.
    VEXcode V5 shows a Drive for command typed in the workspace and the Help open to the right for that command. The help defines Drive for as moves the Drivetrain for a given distance, and explains how to use the command in a project.
  • Make sure you have the hardware required, your engineering notebook, and VEXcode V5 downloaded and ready.
Materials Required:
Quantity Materials Needed
1
VEX V5 Classroom Starter Kit (with up-to-date firmware)
1
VEXcode V5
1
Engineering Notebook
1
Clawbot and Advanced TrainingBot (Drivetrain 2-motor, No Gyro) example project
Step 1: Preparing for the Exploration
Before you begin the activity, do you have each of these items ready? Check each of the following:
  • Are the motors plugged into the correct ports?
  • Are the smart cables fully inserted into all of the motors?
  • Is the Brain turned on?
  • Is the battery charged?
Step 2:  Start a New Project
Before you begin your project, select the correct template project. The Clawbot and Advanced TrainingBot (Drivetrain 2-motor, No Gyro) example project contains the Clawbot's motors configuration. If the template is not used, your robot will not run the project correctly.
VEXcode V5 Toolbar with the File menu open and Open Examples highlighted in a red box. Open Examples is the fourth menu item beneath New Blocks Project, New Text Project, and Open.
Complete the following steps:
  • Open the File menu.
  • Select Open Examples.
Icon reading Clawbot and Advanced Training Bot with a gray robot above the text.
  • Select and open the Clawbot and Advanced TrainingBot (Drivetrain 2-motor, No Gyro) example project.
  • Since we will be programming to control the arm, rename your project ArmControl.
  • Save your project.
  • Check to make sure the project name ArmControl is now in the window in the center of the toolbar.
The project name dialog box in the VEXcode V5 Toolbar reads Arm Control and shows that Slot 1 is selected.
Step 3:  Move the Arm Up
We are now going to begin by programming the arm to raise!
# Library imports
from vex import *
# Begin project code
  • Write the arm_motor.set_position() command as shown above in the programming area to set the starting position for the arm.
  • Add the arm_motor.spin_for() command below the arm_motor.set_position() command as shown above to move the arm up.
VEXcode V5 Toolbar with the slot selection open beside the project name. Slot 1 is selected and highlighted with a red box and the project name reads Arm Control.
  • Select the Slot icon. You can download your project to one of the available slots in the Robot Brain. Select Slot 1.
Image of the Toolbar in VEXcode V5 with a red box around the green arm icon
  • Connect the robot to your computer or tablet. The Brain icon in the toolbar turns green after a successful connection has been made.
Toolbar in VEXcode V5 with a red box around the download button. The icons shown from left to right are Controller, Brain, Download, Run, and Stop.
  • Click the Download button on the toolbar to download the ArmControl project to the Robot Brain.
V5 Brain Home Screen shows the Arm Control project in slot 1 in the bottom left corner. In the row above, the icons read Drive, Devices, Settings, and VEX.
  • Check that the ArmControl project has downloaded to the brain in the slot you chose.
  • Run the project on the Clawbot by making sure the project is selected and then press the Run button. Congratulations on creating your first Claw Arm project!
Step 4:  Try This: Program the Arm Down
Now that you have programmed the arm to move up, you will now program the arm to lower or move down.
Sideview of the V5 Clawbot with its arm down
Image of the VEX V5 Clawbot with its arm down
  • Add a second arm_motor.spin_for() command to your ArmControl project so that the arm raises to 90 degrees, waits 2 seconds, and then back down.
    • Hint: You will need to change the direction within the command.
  • Notice that the arm holds its position while the wait command is running. The motor draws power from the battery to hold the arm up against the force of gravity. That's because the default setting for having the motor stop is the hold setting. There are two other settings for stopping - brake and coast. You will learn about those in another lab.
Step 5:  Complete the Flight Traffic Controller Challenge
Sideview of a V5 Clawbot with the arm raised up and arrows below it indicating up and down motion.
Image of the V5 Clawbot with its arm raised with red arrows pointing up and down, showing how the Clawbot can raise and lower its arm In the Flight Traffic Controller Challenge, the Clawbot must move its arm up and down once for 90 degrees, wait 3 seconds, move the arm up and down two times for 45 degrees, wait 5 seconds, and then move the arm up and down three times for 90 degrees.
Here is a list of the Clawbot's behaviors:
  • Move arm up and then down for 90 degrees.
  • Wait 3 seconds.
  • Move arm up and then down for 45 degrees.
  • Wait 5 seconds.
