Now that you have practiced controlling roll, pitch, and yaw, you are ready to explore a new way to steer! In this lesson, you will learn about the difference between standard and headless steering modes, how each one changes the way you fly the VEX AIR Drone, and how to select the steering mode on the VEX AIR Drone Controller.
So far in this course, you've been using standard steering, where the drone moves based on the direction the drone is currently facing. With headless steering, the drone moves in relation to the drone's starting position, no matter which way the drone has rotated in flight.
In this video, you will learn about:
- How standard steering uses the front of the drone as the reference point for movements.
- How headless steering uses the starting position of the drone as the reference point for movements.
- How to switch between steering modes on the controller.
Practice Mission: Fly Using Headless Steering
Real-World Connections
Drone pilots choose between standard and headless steering based on the task they need to complete and their personal preference. Understanding when to use each mode is an important part of becoming a skilled and confident flyer, whether in a simulator or operating a drone in the real world.
Headless steering is especially useful in situations where the drone is far away, hard to see, or positioned at an unusual angle. For example, pilots filming movie scenes often rely on headless steering to keep their shots smooth, even when the drone rotates to capture a moving subject. Headless steering can also help during long-distance or out-of-sight flights, because the controls stay consistent no matter which direction the drone is facing.
Standard steering, on the other hand, is commonly used in professional drone work that requires precision. Tasks like inspecting buildings, navigating tight spaces, or following specific flight paths are often easier when the controls match the drone’s actual orientation.
Check Your Understanding
Select Return to Units > to move on to the next unit in the course.
