Skip to main content
Session 5
As you prepare to improve your Hero Bot, think carefully about the changes you want to explore. In this session, we'll guide you through making a potential improvement to your robot. Keep in mind, this potential improvement may or may not actually enhance performance—and that's okay! After this session, you'll have the skills to analyze data about your changes, empowering your team to make informed decisions about your robot’s design.
Before you begin, make sure you have the following ready:
Watch the following video to learn more about how one VEX V5 Robotics Competition Team, Eastwood Robotics, approached documenting design changes in their engineering notebook.
The V5 Section of the VEX Library has many articles that may be helpful with robot design and improvement.
Activity: Make an Incremental Improvement
Let's explore ways to improve your Hero Bot! Improvements can involve adding, removing, or modifying parts of your robot. You will collaborate with your team to decide on an improvement to make, and then test the robot's performance with the improvement. You will collect and record data so your team can decide if it's an improvement worth keeping.
Use this task card (Google doc / .pdf / .docx) to guide you through this activity.
  • Document your ideas for changes in your engineering notebook, along with your reasoning.
  • Record data about the effects of any changes as well, so you can make a data based decision.
As you work, perform a Student-Centered Check. Ask yourselves in each area: are we the ones doing the work?
  • Robot: Are we designing, building, testing, coding, and improving our robot?
  • Teamwork: Are we making our strategy, gameplay, and competition decisions?
  • Notebook: If we keep one, are we the ones writing our decisions, iterations, learning, successes, and failures?
All Yes: the work is ours. Any No: it is not yet ours.
Now is a good time to look at the ‘Engineering Design Process — Optimize’ section of the Engineering Notebook Rubric ("Did we make it better") in the Student-Friendly version), and have a discussion about what sets the exemplary, proficient, developing and beginning categories apart in the ‘Mechanisms are Documented’ and the ‘Changes are traceable to results’ rows.
Wrap Up
After your group has collaborated to make, test, and record data about an improvement, come together for a whole-team discussion.
  • What does the data show about the performance of the robot with the improvement?
  • Is this modification one the team wants to keep? Why or why not?
  • What other improvements are needed to optimize how your robot's design helps you to implement your strategy?
  • What did you learn about the robot, your team, or your strategy during this process?
Now that you've created an initial strategy and improved your robot, you are ready to prepare for your first competition!
Select Next Session > to move on to the next session.
