Prepare for the Remix Challenges-Blocks-based
Teacher Tips
Make sure that the students have selected the Clawbot Controller with Events Example project. You can point out to students that there are several selections to choose from on the Open Examples page from the File menu. Remind students that they can refer to the Using Examples and Templates tutorial at any time during the exploration.
You can ask students to add their initials or their name to the project name. This will help differentiate the projects if you ask the students to submit them.
Before you begin your project, select the correct example project. The Clawbot Control example project contains the Clawbot motors and sensors configuration. If the template is not used, your robot will not run the project correctly.
- Go to the file menu, Open Examples, then select the Clawbot Control example project.
Save the project.
- Check to make sure the project name Clawbot Control is now in the window in the center of the toolbar. The Clawbot is now properly configured, and the Clawbot Control project is ready for use.
Now, take a look at how the blocks are being used in this project. In your engineering notebooks, make the following predictions:
- What’s happening when you run this project? What will the Clawbot be able to do?
- What would happen if we didn’t use the <Not> block in this project?
Teacher Toolbox
Stop and Discuss
After students have finished answering the above question in their engineering notebooks, discuss their entries:
Answer Key
Accurate predictions will explain that the Clawbot will be able to move forward, in reverse, and turn using the Joysticks, moving them up and down on the 2 and 3 positions. The Clawbot’s Arm will be able to move up and down using the L1 and L2 buttons, and the Claw will be able to open and close using the R1 and R2 buttons. Advanced responses may even predict that the Arm and Claw positions will hold in place when their buttons are not being pressed and their motors stop.
The [not] block, in this case, tells the Clawbot that when the L and R buttons are not being pressed, the Arm (L buttons) and/or Claw (R buttons) should stop. If the [not] blocks were removed, those Motors would move indefinitely after they were first told to spin.
If time permits, have students remove the <not> block so they can see how it impacts their Clawbot’s behaviors.
