Build Instructions
Teacher Toolbox
Facilitating the Build
In this Seek section, groups will add the Disk Feeder to their Workcell build.
What the Teacher Will Do:
- Tell students get into their groups with their assigned Workcells.
- Instruct groups to follow the Build Instructions linked on this page.
- As groups are building, circle the room and assist as needed.
Go to the V5 Workcell Educator Certification for additional suggestions on facilitating the build.
| Quantity | Materials Needed |
| 1 per group |
V5 Workcell |
| 1 per group | |
| 1 per group |
Engineering Notebook |
| 1 per group |
Device to run VEXcode V5 |
| 1 per group |
Micro-USB cable |
| 1 per group |
Select the button below for the Disk Feeder and Cooperative Systems Build Instructions.
For using multiple systems, select the buttons below for the multi-system Disk Feeder and Cooperative Systems Build Instructions.
Teacher Tips
- Use the open ended wrench to hold the nylock nut in place while screwing in the star drive screw.
Ensure to remove the V5 Smart Cable from the Optical Sensor before detaching it from the Workcell.
For more tips and guidance while building, go to the V5 Workcell Educator Certification.
