Robot to Robot Communication
Teacher Toolbox
Purpose of the Apply Section
What the Teacher Will Do:
- Introduce the Apply reading to your students. Through this reading, they will be learning about robot to robot communication.
For more information on how to facilitate the Apply section, go to the V5 Workcell Educator Certification.
Communications Between Numerically Controlled Machines
Numerically controlled machines have their functions determined and executed by a controller. These include, but are not limited to robots, computer numerically controlled (CNC) machine tools, and 3D printers. In an automated manufacturing work cell, a supervisory controller (generally a programmable logic controller (PLC)) acts as the cell’s main controller working with the controllers of a robot and a CNC of the cell. Communications between the numerically controlled (CNC) machines and other controllers like PLCs are handled through input and output signals (I/Os).
Analog and Digital Signals
Input and output signals are analog or digital in nature.
| Analog Signals | Digital Signals |
Industrial Robot I/Os
Some industrial robots use four different types of input signals and four different types of output signals.
- Analog, digital, group, and robot inputs
- Analog, digital, group, and robot outputs
Analog and digital I/Os are commonly used with outside devices and machines. For example, a robot could receive a digital input signal from a proximity switch when a part gets near that switch. The robot could also send out a digital output signal to a CNC machine. This signal could check if the CNC machine is available to move a part to be worked on.
A group I/O is a combination of multiple digital input and output signals working together.
Robot inputs and outputs are reserved for sensors or devices like pneumatic valves placed on the robot’s arm. Robot I/Os are usually digital.
Handshaking
Handshaking is the process that two network devices use to initiate communications between one other (a laptop computer and a wi-fi router, a modem, and another modem). It starts when one device sends a message to another device indicating that it wants to establish a communications channel. The two devices then send several messages back and forth that enable them to establish a communications protocol. Industrial robotic controllers initiate communication in a similar fashion.
Robot/CNC Handshake
In the case of industrial robots, as mentioned earlier, they have to work with other machines within their work-cell by communicating through I/Os.
For example, a robot to CNC handshake asks the CNC machine if it is available to work on the part the robot is holding. The robot waits for approval from the CNC machine. Once the approval comes, the robot places the part in the machine.
Robot/Robot Handshake
If two robots have to work in a work cell in a coordinated manner or in very close proximity, they have to use handshaking to prevent collisions.
For example, two robots can each use two digital outputs and two digital inputs to communicate with one another. The digital output for one robot is connected to the digital input of the second robot and vice versa. The handshaking is handled as two background tasks in the robots’ main program to keep the two robots from colliding with one another.
Transmitting signals/packets of data:
There are several ways in which robots can transmit their input/output signals and packets of programmed information. Some of these methods include:
Wired communication - with this type of communication the two robots are hardwired together using some type of communication cabling. Traditionally this has been the most common method of connecting industrial devices because it's robust, nearly fail-proof, and allows for high speeds of transmission.
Wi-Fi communication - uses Wi-Fi protocols to communicate packets of information between the two robotic systems. This allows communication between devices without having them connected to one another. It also allows for interfacing with internet-enabled devices.
Bluetooth communication - uses Bluetooth radio waves to connect the robotic systems together. This allows devices to be paired together for communication when the devices are in fairly close proximity.
Motivate Discussion
Question: What are the two different types of input/output signals and what is the main difference between them?
Sample Solution: The two different types of input/output signals are digital signals and analog signals. An analog signal is continuous in time and a digital signal is discrete.
Question: What are the four different types of IO signals used with industrial robots?
Sample Solution: The four different types of I/O signals used with industrial robots are analog, digital, group, and robot.
Question: What is handshaking and why is this important?
Sample Solution: Handshaking is the process that two network devices use to initiate communications between each other. It is important so the two devices can establish a communication protocol.
Question: Traditionally what is the most common method of communication used with industrial devices?
Sample Solution: Wired communication is the most traditionally used, a common method of communication with industrial devices.
