Skip to main content
Answer Key
Summative Assessment Answer Key
  1. What sensor is used to detect the location of disks in this stack?
    Line Tracker.
  2. Which of these is the best description of how My Blocks are used in a VEXcode V5 project?
    To create a sequence of blocks that can be used multiple times throughout a project.
  3. Based on this output, what color disk does the Optical Sensor detect?
    Red.
  4. What triggers the Exit Conveyor Belt motor to stop running in this project?
    Exit Sensor reports a value greater than 35%.
  5. What type of value does the Line Tracker return?
    Percentage values from 0 to 100%.
