Skip to main content
Design, Develop, and Iterate on your Project
Answer the following questions in your engineering notebook as you design your project.
  • What type of robot dance will you create? Explain with details.
  • What types of loops will you use and why?
  • What steps will you follow to test the dance? Explain with details.
In order to help you plan, click here (Google / .docx / .pdf) for a few example dance moves that you might include in the Clawbot's dance.
Follow the steps below as you create your project:
  • Plan out the dance using drawings and pseudocode (Google / .docx / .pdf).
  • Use the pseudocode you created to develop your project using VEXcode IQ.
  • Run your project to test it often and iterate on it using what you learned from your testing.
  • Share your final project with your teacher.
If you're having trouble getting started, review the following in VEXcode IQ:
  • Example projects
VEXcode IQ Toolbar with the File menu open, and Open Examples selected with a red box. 'Open Examples' is the fourth item in the menu.
  • Using Loops tutorial
VEXcode IQ Toolbar with the Tutorials icon called out with a red arrow, to the right of the File menu.
  • Previous versions of your project
  • The Help feature to learn more about the blocks
