The M.A.D. Box's Gears
Step 1: M.A.D. Box's Step 2: 12 and 36 Tooth Gears
In Step 2 of the Build Instructions, the 12 Tooth Gear was already on the shaft that connected the M.A.D. Box's handle on that side of the build.
- Build Expert, find that side of the M.A.D. Box and show it to your teammates. Then demonstrate that when that handle is turned, the shaft turns the 12 Tooth Gear (driving gear - input) which then turns the 36 Tooth Gear (driven gear - output) that is being added in this step of the build.
- What is the gear ratio of these two gears?
- Calculator, figure out the equation below and have the Recorder check it.
The 3:1 ratio tells us that the driving 12 Tooth Gear needs to turn three times in order to turn the 36 Tooth Gear once.
That leads to a mechanical advantage of torque. What is torque?
Torque is a mechanical advantage that makes the output of the driven gear or machine more powerful. In this case, the M.A.D. Box had three times as much input as output which makes it more powerful.
- Recorder, be sure to add notes to the engineering notebook about the mechanical advantage of torque within the M.A.D. Box.
Step 2: M.A.D. Box's Step 10: 36 and 12 Tooth Gears
In Step 10 of the Build Instructions, the other side of the M.A.D. Box was connected. It had a 36 Tooth Gear on the shaft with the handle.
- Build Expert, find that side of the M.A.D. Box and show it to the group. Then demonstrate that when that handle is turned, the shaft turns the 36 Tooth Gear (driving gear - input) which then turns the 12 Tooth Gear (driven gear - output).
- Calculator, figure out the equation below and then have the Recorder check it.
The 1:3 ratio tells us that the driving 36 Tooth Gear only needs to turn one time to turn the 12 Tooth Gear three times.
That leads to a mechanical advantage of speed.
Speed is a mechanical advantage that makes the output of the driven gear or machine faster. In this case, the M.A.D. Box has three times as much output as input rotations which makes it faster.
- Recorder, be sure to add notes to the engineering notebook about the mechanical advantage of speed within the M.A.D. Box.
Step 3: M.A.D. Box's Compound Gear Ratios
- Build Expert, turn the handle connected to the 36 Tooth Gear slowly and let the group watch how fast the other handle turns.
- Recorder, after reading the description below, explain what a compound gear ratio is in the engineering notebook.
The gear ratio for the 36 Tooth Gear turning the 12 Tooth Gear was 1:3 with the mechanical advantage of speed. But when you turn the handle connected to the 36 Tooth Gear once, the other handle turns many more than three times.
That is because the M.A.D. Box uses a compound gear ratio. The M.A.D. Box's compound gear ratio is created by having 36 Tooth Gears and 12 Tooth Gears share the same shafts.
A compound gear ratio multiplies the mechanical advantage of speed or torque within a mechanism.
The red arrows in the image above show the shafts that have both 36 Tooth and 12 Tooth Gears on them. Those shafts connect the first, second, and third gear ratios to each other. When the shaft turns, both the 12 Tooth and 36 Tooth Gears on the shaft turn.
This multiplies the mechanical advantage created by each gear ratio because they are connected into a compound gear ratio.
The M.A.D. Box has two compound gear ratios because you can give it input on either side - one leading to a torque advantage and the other leading to a speed advantage.
To calculate the compound gear ratio on one side of the M.A.D. Box, we need to find the three gear ratios in the build from that input to the output, and then multiply them by each other.
- Build Expert, find the side of the M.A.D. Box where the input handle turns the 36 Tooth Gear and show it to the group. Hint: It is the handle at the bottom of the image above. Point out in the build to review where the three gear ratios are found.
- Remember, all of the driving gears are 36 Tooth Gears and all of the driven gears are 12 Tooth Gears.
- Calculator and Recorder, complete and check the equations below:
- The entire team should try to answer the following questions: What does the 1:27 Compound Gear Ratio mean? When the handle with the 36 Tooth Gear is turned once, how many turns of the other handle should there be?
- The Recorder should organize the team's best answers and write them in the engineering notebook.
Step 4: The M.A.D. Box's Compound Gear Ratio for Torque
- Build Expert, find the side of the M.A.D. Box where the input handle turns the 12 Tooth Gear and show it to the group. Hint: It is the opposite side of the M.A.D. Box as you were using above. Point out that when using this input handle, all of the driving gears are 12 Tooth Gears and all of the driven gears are 36 Tooth Gears.
- The entire team should try to answer the following questions: What is the Compound Gear Ratio and what does it mean? How many times do you turn the handle with the 12 Tooth Gear in order to turn the other handle once?
Step 5: Thinking about the M.A.D. Box's Design
Why aren't the M.A.D. Box's six gears all in one row?
A design where all of the gears are meshed in a line is called a gear train. The image above shows the M.A.D. Box's gears as a gear train.
A gear train like this only has one gear ratio and it is not a compound gear ratio. The ratio is either 1:3 or 3:1 depending on whether the first or last gear is the driving gear. Only the sizes of the first and last gears in this gear train matter to the gear ratio.
The gears between the first and last gears are called idler gears. They do not increase the power or speed. Idler gears only change the direction of the rotation.
Why wasn't the M.A.D. Box designed with only two gears: a small gear and a gear with 27 times more teeth?
The Compound Gear Ratio of the M.A.D. Box is 1:27 or 27:1. You might wonder why it wasn't designed with only two gears: the 12 Tooth Gear and a 324 Tooth Gear. That would have led to a 1:27 or 27:1 gear ratio.
There are two reasons why the M.A.D. Box wasn't designed with a 324 Tooth Gear.
The first reason is that a VEX Plastic 324 Tooth Gear doesn't exist. The largest gear in the kit is a 60 Tooth Gear. When engineers design builds, they need to take into account what materials are available and a 324 Tooth Gear was not available.
The second reason is that a 324 Tooth Gear, if available, would be very large. A gear that size would make the build difficult to handle. The compound gear ratio makes better sense for designing a handheld device. When engineers design builds, they need to take into account how the device will be used by consumers.
