Lesson 1: Getting Started with VEXcode VR Python
This lesson will show you how to get started with VEXcode VR Python. This lesson will also direct you to articles in the VEX Robotics STEM Library.
Learning Outcomes
- Identify how to launch VEXcode VR Python.
- Identify the features of a VR Robot.
- Identify the features of the VEXcode VR Playgrounds.
- Identify how to access help in VEXcode VR Python.
Launching VEXcode VR Python
VEXcode VR Python does not require a download in order to get started. VEXcode VR Python can be run on most popular browsers and on most devices. For more information on the browser supported by VEXcode VR, see this STEM Library article.
To launch VEXcode VR Python, first go to vr.vex.com. VEXcode VR may launch in Blocks mode. To switch to Python, select 'File' in the Toolbar, then select 'New Text Project', as shown in this video clip. You are now ready to create a project in VEXcode VR Python.
Features of the VR Robot and VEXcode VR Playgrounds
The VEX VR Robot is equipped with sensors, controls, and many physical features. In VEXcode VR, the robot is already preconfigured. This eliminates the need for a robot configuration or a predetermined template project that you would normally have to use with a physical robot. Read this STEM Library article to learn about the VR Robot's features.
A Playground is a virtual space in which your VR Robot can interact and move. VEXcode VR includes a variety of different playgrounds. Read this STEM Library article to learn about the VEXcode VR Playgrounds.
Accessing Help in VEXcode VR Python
There is also help information located in VEXcode VR Python. You can use the built-in Help at any time to learn more about commands and how they are used in a project.
- Help can be accessed by selecting the Help icon beside an individual command. To close the Help, select the arrow to the right of the Help icon in the Help window. See the video below for how to access Help in VEXcode VR Python.
Video file
To learn more about accessing Help in VEXcode VR Python, see this article.
