Pick it, Score it!
Use [Spin for], [Spin to position], and [Turn for] blocks to code Virtual Byte, the Hero Bot, to pick up the Green Block in front of it and score the Block into Goal II.
- Select the VIQRC Virtual Skills - Full Volume Playground.
- Code the robot to spin the Intake Motor Group to pick up the Green Block.
- Code the robot to spin the Arm Motor Group to raise the Arm to a desired position for scoring.
- Turn the robot toward Goal II.
- Code the robot to spin the Intake Motor Group to drop the Green Block into the Goal.
Helpful Hints
- Use the spin IntakeMotorGroup block from the Motion category and select the forward direction to intake an object.
- Matching Python command:
- Use the spin IntakeMotorGroup block from the Motion category and select the reverse direction to drop an object.
- Use the spin ArmMotorGroup to position block from the Motion category to raise and lower the Arm.
For more information about the robot features in VIQRC Full Volume for VEXcode VR, please see this article.
