Skip to main content
STEMLabs IQ
Lab 3 - To Do, or Not To Do
Decision Making
Decision Making
TRUE and FALSE paths
Decision Making
At their most basic level, programs are written to accomplish simple sequences of behavior. For example, you might want your robot to drive forward and also make some turns to reach a destination. But, what if you want your robot to wait for the right time to start driving forward and complete its route? That would require programming with conditional statements. You would use a conditional statement to define what the "right time to start" is within your project. Maybe the "right time" is after a button is pressed or when a sensor detects a specific level and then it starts driving. When you watch the robot's behavior, it will seem like it is deciding when to start driving but it's because you set the condition for when driving should start.
Conditional statements are powerful programming statements that use a boolean (TRUE or FALSE) condition and allow you to develop projects that have the robot behave differently depending on what it senses.
In the following example, if the Brain Up button is pressed (TRUE) the robot will drive forward. If the Brain Up button is not pressed (FALSE) the robot will stop driving. This shows the robot only driving forward when the Brain Up button is pressed, otherwise the robot stops.
