Skip to main content
Robo Rally Preview
  • 12 - 18 years old
  • 45 minutes - 4 hrs, 35 min
  • Beginner
Preview image
Description
Students are asked to use proportional reasoning and scale to design a racecourse for the Speedbot.
Key Concepts
  • Mathematical Reasoning
  • Proportional Reasoning
  • Iterative Design
Objectives
  • Create a racecourse by planning with scaled drawings.
  • Analyze relationships between scaled measurements.
  • Practice converting units.
  • Understand the use of scales and proportional reasoning.
Materials needed
  • 1 or more VEX V5 Classroom Starter Kits
  • Roll of Tape
  • Meter Stick or Ruler
  • Calculator
  • Engineering Notebook
  • Stopwatch
  • Multiple boxes
  • 3-Ring Binders
Facilitation Notes
  • Ensure all required parts for the build are available prior to starting this STEM Lab.
  • Although the V5 Robot Brain is included in the build of the VEX V5 Speedbot, no programming is required.
  • Make sure that there is ample space in the classroom to measure out and tape the field area for the racecourse that will be used.
  • Providing a set space to create a racecourse within can help expedite initial decisions for the design area.
  • An engineering notebook can be as simple as lined paper within a folder or binder. The notebook shown is a more sophisticated example that is available through VEX Robotics.
  • During the iterative design process prior to the challenge, teams should be testing the accuracy of their measurements and mathematical conversions.
  • The approximate pacing of each section of the Stem Lab is as follows: Seek- 125 minutes, Play- 85 minutes, Apply- 15 minutes, Rethink- 45 minutes, Know- 5 minutes.
Further Your Learning
Math
  • Add other items to the physical racecourse, based on scale. Some items could include, stands, a press box, concession stand, trees, benches, etc.
  • Draw a map of the school campus or other well-know location in the school community with the correct scale.
Social Studies
  • Look at various maps to compare the scales used. Have the students create their own set of questions and then trade with each other to solve.
  • Research how cartographers use technology to help create more accurate maps.
Educational Standards
Standards for Technological Literacy (STL)
  • 4.E
Next Generation Science Standards (NGSS)
  • HS-ETS1-2
  • HS-ETS1-3
Common Core State Standards (CCSS)
  • RST.9-10.3
  • RST.11-12.3
  • HSN.Q.A.1
  • HSA.CED.A.1
  • MP.4
  • MP.5
  • MP.6
  • CCSS.MATH.CONTENT.6.RP.A.1
  • CCSS.MATH.CONTENT.6.RP.A.3.D
Texas Essential Knowledge and Skills (TEKS)
  • 126.40.c.1
  • 111.39.c.1
