Skip to main content
Lesson 1: Kit Introduction
Before you can take flight, every drone pilot needs to understand their equipment. In this lesson, you will explore the parts that make up your VEX AIR Drone Kit and learn the purpose of each element. You will use your physical kit and resources like the VEX Library as your guide.
Top and bottom of a VEX AIR Drone Kit shown side by side.
By the end of this lesson, you will be able to identify each part, explain what it does, and understand how all the components work together.
Mission: Explore the Kit
Real-World Connections
Three drones fly above a field of crops spraying a liquid onto the crops.
Industry
In construction and agriculture, drones help professionals see things from above. They can survey land, monitor crop growth, and check structures safely and quickly. This saves time and gives workers data they can’t get from the ground.
Two firefighters observe drone camera footage on a tablet at the site of a forest fire.
Public Safety
Search and rescue teams use drones to find missing people in hard-to-reach areas. Firefighters and police use them to assess dangerous situations from a safe distance. Quick, accurate aerial views can save lives.
A drone carries a small box through a warehouse.
Delivery and Transportation
Companies are developing drones to deliver packages, medicines, and supplies. In areas that are hard to reach by road, drones can make transportation faster and more efficient.
A man in sunglasses smiles while looking down at a drone controller in the background, while in the foreground, the drone flies above a wetland environment.
Recreation
Many people fly drones just for fun or to capture photos and videos from new and unique perspectives. Recreational flying helps pilots build the same skills professionals use like precision, coordination, and problem-solving.
Check Your Understanding
Select Next > to move to the next lesson.
