1725569733
Skip to main content
Getting Ready to Code
There are built-in resources in VEXcode EXP available to help you get started coding. You can access Tutorial Videos, Help, or Example Projects to learn more about things like saving, downloading, and running your project, how to use a specific block, or getting started with a project.
Tutorial Videos
To access tutorials, select the 'Tutorials' icon in the VEXcode EXP Toolbar, as shown here.
The following tutorial videos may be helpful to get started with this Unit:
  • Getting Started
  • Naming and Saving Your Project
  • Download and Run a Project
VEXcode EXP Toolbar with the Tutorials icon called out in a red box, to the right of the File menu.
Built-in Help
To access Help, select the 'Help' icon in VEXcode EXP, as shown here.
Then, select a block or command to learn more about it.
The help feature offers block or command-specific information, including things like how they can be used in a project.
VEXcode EXP Toolbar with the Help icon called out in a red box, to the right of the Console.
Example Projects
To access Example Projects, select 'File', then 'Open Examples', as shown here.
For a beginning project to help you get started coding, you can use an Example Project. Example Projects include Templates for different VEX EXP builds, as well as sample projects for a variety of features and functions.
In this Unit, the following Template example project can be used:
  • Clawbot (Drivetrain 2-motor)
VEXcode EXP Toolbar with the File menu open, and Open Examples selected with a red box. 'Open Examples' is the fifth item in the menu, beneath 'New Blocks Project', 'New Text Project', 'Open', and 'Open Recent'.
What is Next?
In this Lesson, you built the Clawbot and got ready to code with VEXcode EXP.
In the next Lesson, you will:
  • Learn to design effective manipulators for a specific task.
  • Drive your Clawbot to score Buckyballs and rings on two platforms
  • Compete in the Push and Place Challenge!
EXP Clawbot placing a Buckyball on a medium platform using its claw arm.
Select < Return to Lessons to go back to the Lesson Overview.
Select Next Lesson > to continue to Lesson 2, and learn how to design manipulators to complete a specific task.
