Skip to main content
Teacher Portal
Pacing Guide
This unit should be implemented to supplement student learning on the concepts of Coding and Problem Solving.
STEM Labs can be adapted in various ways to fit into any classroom or learning environment. Each STEM Lab includes the following 3 sections: Engage, Play, and Share (optional).
Each STEM Lab in this unit can be completed in as little as 40 minutes
Section Summary
The Engage and Play sections, which contain the primary learning activities, can be completed within 40 minutes. The Share section, which enables students to express their learning is optional, but estimated at around 3-5 minutes per group.
Click on the tabs below to view descriptions of the Engage, Play, and Share sections of the STEM Lab.
The Pacing Guide
The pacing guide for each Lab provides step-by-step instructions on What, How, and When to teach. The STEM Lab Pacing Guide previews the concepts that are taught in each section (Engage, Play, and Share (optional)), explains how the section is delivered, and identifies all the materials that are needed.
Making This Unit Fit Your Unique Classroom Needs
Not every classroom is the same, and teachers face a variety of implementation challenges throughout the year. While each VEX GO STEM Lab follows a predictable format, there are things that you can do in this Unit to help make it easier to meet those challenges when they arise.
  • Implementing in less time:
    • Have students watch the Connecting To Your Robot and Configuring Your Robot tutorial videos to shorten the instruction in Lab 1.
    • To combine Labs 2 and 3 into a shorter time, show the Driving Your Robot tutorial video to show students how to use [Drive for] and [Turn for] blocks in a project.
    • You can prescribe one robot job for the entire class in Lab 4 to teach the STEM Lab in a shorter period of time, with a more coding oriented focus.
  • Reteaching Strategies: If students are struggling to build a successful project in Labs 3 and 4, show them the Sequencing tutorial video to reiterate the importance of sequencing to building a project that works as intended. Have students who need more practice with Drivetrain commands watch the Driving Your Robot tutorial video before beginning the challenge in Lab 4.
  • Extending this Unit: You can show students the Turning Your Robot tutorial video to learn about different Drivetrain turn blocks, and how they are used. Offer students an additional challenge to use a different turning block in their projects during Labs 3 or 4.
  • If students get done building at different times, there are a number of meaningful learning activities early finishers can participate in as the rest of the group finishes building. View this article for several suggestions about how to plan for engaging students who finish building earlier than others. From establishing classroom helper routines to completing short activities, there are many ways to keep all students engaged throughout class building time.
The following VEXcode GO resources support the coding concepts that are taught in this STEM Lab Unit. Above are some ways to use these resources to support your implementation needs from catching up for missed class time to remote learning and differentiation. Below is more information about these resources, so you can be confident and prepared for the suggested implementations or when using these resources to best suit your own unique teaching environment.
VEXcode GO Resources
Concept Resource Description
Connecting to a VEX GO Brain
Connecting to Your Robot
Tutorial Video
Shows the steps to connect a VEX GO Brain to a device in VEXcode GO.
Configuring a VEX GO Robot
Tutorial Video
Describes the steps to configure a robot in VEXcode GO.
Drivetrain Commands
Driving Your Robot
Tutorial Video
Describes basic movements using the [Drive for] and [Turn for] blocks in a project.
Drivetrain Commands
Drivetrain Moves & Turns
Example Project
Shows the Drivetrain blocks in a project to drive the Code Base in a specific shape. Use this with students for additional practice or exploration with building basic movement projects.
Drivetrain Commands
Turning Your Robot
Tutorial Video
Describes the difference between the kinds of Drivetrain turn blocks.
Drivetrain Commands
Turning Accurately
Example Project
Shows the different kinds of Drivetrain turn blocks used in a project. Use this with the Turning Your Robot tutorial video for an additional challenge.
Sequencing
Sequencing
Tutorial Video
Defines sequence and explains the importance of ordering blocks in a project so the robot performs as you intend it to.
Sequencing
Stepping Through a Project
Tutorial Video
Explains the Step feature and shows how it highlights blocks in a project as they are executed by the robot. Use this to further show the connection between blocks and robot behaviors.
Using VEXcode GO Help
You can use the Help feature together with your students as an additional means to explain how specific blocks are functioning in a project. After reading the description for, or with, your student, you can use the example shown for extra practice with that block. Ask students to describe what the robot will do in the project shown, and help them make connections to how that is similar or different to the project they are working on.
Blocks in this Unit include:
  • [Drive for]
  • [Turn for]
