Skip to main content
Lesson 3: Move in Four Directions
It’s time to level up your challenge! In this lesson, you'll explore coding your VEX AIM Coding Robot in four directions using VEXcode AIM. You’ll build on what you learned in the previous lessons to code the robot to move left and right. Then you'll create a project to navigate the robot around the obstacles on the field, and back to its starting location!
Watch the video below to learn about:
  • Changing the direction parameter to left and right in a Move for block.
  • Sequencing multiple blocks based on your plan.
  • Basic debugging such as finding and fixing an error in a project.
  • Using measurements to determine parameters.
Guided Practice
Wrap-Up
Select Next > to explore an example project.
