Skip to main content
Challenge Mission
Throughout this course, you've learned a great deal about how to fly the virtual VEX AIR Drone in the VEX AIR Flight Simulator. Now you're going to put your skills to the test as you fly through your most complex mission yet! Your goal is to use the VEX AIR Drone Controller to fly through all the rings on the field as quickly as possible. To prepare for your flight, you'll develop a flight plan, practice and refine it, then take flight to balance speed and precision in real time.
A screenshot of the VEX AIR Flight Simulator Rings layout with the drone hovering above the platform, and the rings visible around the field.
Hover & Discover
Before taking off, pilots create a flight plan to map out their route, controls, and potential challenges. Planning helps pilots fly more efficiently, avoid mistakes, and stay safe—especially for missions with multiple movements or obstacles. In this challenge, you'll use the same approach real pilots rely on before every flight. You'll develop, practice, and refine your flight plan in preparation for your mission.
Mission: Ring Flight Challenge
Phase 1: Develop a Flight Plan
Phase 2: Practice Your Plan
Phase 3: Refine Your Flight Plan
Phase 4: Fly the Ring Flight Challenge Mission
Select Return to Units > to move on to the next unit.
