Skip to main content
Introduction
In this unit, you will apply everything you've learned to complete an open-ended challenge. Your goal is to fly through all the rings in the VEX AIR Flight Simulator as quickly as you can with as few collisions as possible! You will create a flight plan, practice and refine it based on your results, then complete your final challenge mission.
VEX AIR Drone flying in the simulator about to enter a blue ring on the floor of the field.
Vocabulary
Select Next > to move to the next lesson.
