Skip to main content
Lesson 5: Disk Maze Challenge Steps
Disk Maze Challenge
In this challenge, create a project where the VR Robot navigates the Disk Maze Playground from start to finish using the Eye Sensor. The VR Robot should return back to the starting position after the VR Robot reaches the end (red disk) and navigate the Disk Maze on a loop forever.
A top-down view of the VR Disk Maze Playground, with the VR Robot having reached the final red disk and now turning to drive back to the starting goal. An arrow indicates the path that it should take to begin repeating the Disk Maze again.
Follow these steps to complete the challenge:
  • In this video, you will see that the robot starts on the green arrow near the lower left corner of the playground, opposite the first green disk. To navigate the maze, the robot drives forward to the green disk and turns right. It then drives to the next blue disk and turns left. The robot repeats this with the next three blue disks. Then the robot drives to the green disk and turns right, drives to the final blue disk and turns left, drives to the final green disk and turns right. The robot then drives and stops when the red disk is detected, indicating it has reached the end of the maze. The robot then turns right and drives to the start to repeat the maze.
  • Create a new project or load a project from previous Lessons in this Unit.
  • Rename the project Unit7Challenge.
  • Launch the Playground window.
  • Load the Disk Maze Playground.
  • Add the blocks necessary to navigate the VR Robot from the start to the finish of the Disk Maze. Remember that if you have a VEXcode VR Premium account, you can use a combination of both VEXcode Blocks and Switch blocks to help you transition from block-based to text-based coding. Switch blocks are located within the Switch section of the blocks Toolbox. You can also convert VEXcode blocks to Switch blocks by selecting a block and choosing, "Convert block to Switch block."
  • The VR Robot should return back to the starting position after the VR Robot reaches the end (red disk) and navigate the Disk Maze on a loop forever.
  • The VR Robot should detect all four colors (green, blue, red, and none).
  • Start the project to test if it works.
  • If the project is not successful, edit and try again. Continue to revise and run the project until the VR Robot successfully navigates the Disk Maze on a loop, forever.
  • Save the project once the VR Robot successfully navigates the Disk Maze on a loop, forever.
Congratulations! You have successfully completed the Disk Maze Challenge!
Questions
Please select a link below to access the lesson quiz.
Google Doc / .docx / .pdf
