Lesson 3: Post-Project Summary
When this project is run, the VR Robot continues to drive forward even when colliding with the first green disk.
This project only instructs the VR Robot to check the conditions of each [If then] block once at the beginning of the project.
- The [If then] block is different from the [Wait until] block.
[Wait until] blocks do not require a decision to be made by the VR Robot. When the condition is TRUE, the [Wait until] block runs the next block in the stack. When the condition is FALSE, the [Wait until] block continues to wait until the condition is TRUE and stops the rest of the project from running.
[If then] blocks require the VR Robot to make a decision. If the condition is TRUE, then the blocks inside the [If then] C block are run. If the condition is FALSE, then the blocks inside the [If then] C block are skipped.
- The VR Robot will continue to drive forward since the last [If then] block in the stack was reported as TRUE and all other blocks were reported as FALSE at the beginning of the project.
- Save the project before moving on to the next Lesson.
