Implementing VEX GO STEM Labs
STEM Labs are designed to be the online teacher’s manual for VEX GO. Like a printed teacher’s manual, the teacher-facing content of the STEM Labs provides all of the resources, materials, and information needed to be able to plan, teach, and assess with VEX GO. The Lab Image Slideshows are the student-facing companion to this material. For more detailed information about how to implement a STEM Lab in your classroom, see the Implementing VEX GO STEM Labs article.
Goals and Standards
Goals
Students will apply
- How to use an Adaptation Claw as a mechanism to pick up objects in the classroom.
Students will make meaning of
- How mechanisms are used in everyday life to make tasks easier such as using a pencil sharpener instead of sharpening your pencil by hand.
- How mechanisms can be used to solve real world problems such as using the Adaptation Claw to pick up objects with limited mobility.
Students will be skilled at
- Using the Adaptation Claw to effectively pick up objects of different sizes and weights in the classroom.
- Using a checklist to record data while testing the ability of the Adaptation Claw to pick up items in the classroom.
- Using data to make changes to the Adaptation Claw to effectively pick up one classroom object they struggled to pick up initially.
- Making changes to the Adaptation Claw.
Students will know
- How the Adaptation Claw functions and moves.
- How to use the Adaptation Claw as a mechanism.
- How the Adaptation Claw is a mechanism that can be used to help make life easier for people with limited mobility such as the elderly picking up items.
Objective(s)
Objective
- Students will describe how tools or mechanisms can be used to solve real world problems.
- Students will evaluate the use of the Adaptation Claw to determine if the Adaptation Claw is the appropriate tool for the task.
Activity
- During Engage, students will discuss mechanisms they have seen or experienced in the real world that make things easier.
- In Play Part 1, students will use a checklist to evaluate which objects can be picked up by the Adaptation Claw.
Assessment
- Students will explain how the Adaptation Claw can be used in real-world applications during the Mid-Play Break. During the Share section, students will describe how a mechanism can make life easier.
- In Play Part 2, students will evaluate and adapt their Adaptation Claw to successfully pick up a new object.
