Skip to main content
Teacher Portal
Implementing VEX GO STEM Labs
STEM Labs are designed to be the online teacher’s manual for VEX GO. Like a printed teacher’s manual, the teacher-facing content of the STEM Labs provides all of the resources, materials, and information needed to be able to plan, teach, and assess with VEX GO. The Lab Image Slideshows are the student-facing companion to this material. For more detailed information about how to implement a STEM Lab in your classroom, see the Implementing VEX GO STEM Labs article.
Goals and Standards
Goals
Students will apply
  • How to ask permission and give attribution when incorporating others’ ideas into a project.
  • How to collaborate with others to create the most efficient project to move cooling cells.
Students will make meaning of
  • Why it is important to ask permission and provide attribution when using the ideas of others.
  • How the sharing of ideas with a diverse group of people leads to better projects.
Students will be skilled at
  • Using build instructions to build the Super Code Base 2.0.
  • Connecting a Brain to a tablet or computer in VEXcode GO.
  • Saving and naming projects in VEXcode GO.
  • Adding VEXcode GO blocks to a project.
  • Using Drivetrain blocks in a project to have the Code Base drive to a specific location.
  • Using the Energize electromagnet block to pick up and drop off a Disk.
  • Changing parameters in VEXcode blocks.
  • Starting and stopping a project in VEXcode GO.
  • Giving attribution to other groups when using their ideas.
  • Collaborating with members of their group and other groups.
  • Applying feedback from those with differing perspectives to improve a project.
Students will know
  • How incorporating others’ ideas through collaboration helps to create more efficient projects to move cooling cells.
Objective(s)
Objective
  1. Students will cite and attribute ideas that come from other groups when those ideas are used in a VEXcode GO project.
  2. Students will develop a collaborative VEXcode GO project to pick up and deliver cooling cells.
Activity
  1. In Play Part 2, students will ask permission to incorporate the feedback and ideas of others into their projects, and give attribution where needed.
  2. In Play Part 1, students will collaborate within their groups to develop a VEXcode GO project to pick up and deliver cooling cells.
Assessment
  1. In Share, students will explain what ideas they used that came from other groups and how they attributed those ideas to the other groups.
  2. In the Mid-Play Break, students will share the projects they created and tested in Play Part 1. In Play Part 2, students will then collaborate with other groups to try and make their project more efficient.
Connections to Standards
