Skip to main content
Teacher Portal
Engage
Launch the Engage Section
ACTS is what the teacher will do and ASKS is how the teacher will facilitate.
ACTS ASKS
  1. Show students the Turbines Tile from the Stage 4 Field, or the image of the turbines on the field in the Image Slideshow, to help prompt ideas. Point out the turbines, and how they can slide along to be near the red and white beams.
  2. Have students share their ideas about how they think the turbines are constructed. Guide them to connect how things can move across the field in this Lab compared to Lab 1 and Lab 2 with sensors and the pipeline.
  3. Show students the image of the clam on the Field in the Image Slideshow. Guide students to think about how they used the Hero Robot to lift objects in previous Labs, and how that strategy can be applied here.
  4. Note student responses on the board. You may want to leave them visible to reference throughout the Lab.
  5. Have students brainstorm ideas for how to move the turbines using the Hero Robot. Have students brainstorm ideas for how to open the clam. You may want to have a robot, the turbines, and the clam as a visual aid, as students share ideas about how to accomplish the competition tasks.
  1. The new element on the Field for this Lab has turbines that slide along from white to red beams. How do you think we can slide the turbine to be in place with the red beam?
  2. What do you notice about how the turbines move, that is similar or different to the sensors or pipeline in Lab 1 and 2?
  3. What do you notice about the clam? What is similar or different about lifting the sensor to the volcano compared to opening the clam?
  4. What is something you remember about how your team worked together in the last Lab, that could help you be successful in this one?
  5. How do you think you will need to drive your Hero Robot to score points in this competition?
Getting the Students Ready to Build
Before we can drive our Hero Robots to move the turbines, open the clam and deliver the pearl, we first need to build our competition Hero Robot.
Note: If you have already built your Competition Advanced 2.0 Hero Robots, you can skip this section.
Facilitate the Build
  1. InstructInstruct students to join their group, and have them complete the Robotics Roles & Routines sheet. Use the Suggested Role Responsibilities slide in the Lab 4 Image Slideshow as a guide for students to complete this sheet.
    Instruct students that the competition Hero Robot is built in two stages. First, they will build the Competition Base 2.0, then they will add onto that to build the Competition Advanced 2.0 Hero Robot.
  2. DistributeDistribute build instructions for the Competition Base 2.0 to each team. Journalists should gather the materials on the checklist for the Competition Base 2.0 to begin.
    Front view of a completed VEX GO Competition Base Hero Robot build.
    As students complete the Competition Base, have them check in with you. Then, distribute build instructions for the Competition Advanced Hero Robot. Students will add onto the Competition Base to build the Competition Advanced Hero Robot. Journalists should gather the materials on the checklist.
    Front view of a completed VEX GO Competition Advanced Hero Robot build.
  3. FacilitateFacilitate the building process.
    • Builders and Journalists should begin building based on their responsibilities in the Lab 4 Image Slideshow.
    • Depending on the amount of time you have, you may want to have students build the Competition Base 2.0, then stop, and resume building during the next class time.
    • Circulate around the room to help students with building or reading instructions where needed. Remind students that they can orient the pieces they are holding and building with the same way they are shown in the build instructions, in order to help them be successful in their build.
    • Engage students' prior knowledge by asking questions about how this build is similar or different to other VEX GO builds that they have used before, like the Code Base. Why do they think that is? What might the competition robot be able to do that is new or different?
  4. OfferOffer positive reinforcement for teams that are working well together, taking turns, and using respectful language as they are building. If there are particular teams or students that excel at building, offer them the opportunity to help teams that may be struggling with the build.
Teacher Troubleshooting
Facilitation Strategies
  • Allow extra time in the Engage section if you choose to have students build Stage 4 of the Ocean Science Exploration Field together with you. This stage builds the Lab to add to the Field. All elements from Stage 1 stay intact, and are part of this stage as well. To help students stay organized, divide up build instructions by team. Suggestions for how to do this include:
    • Team A completes steps 1-11 of the Clam build instructions
    • Team B completes steps 12-21 of the Clam build instructions
    • Team C completes steps 22-31 of the Clam build instructions
    • Team D completes steps 32-37 of the Clam build instructions
    • Team E completes steps 38-43 of the Clam build instructions
    • Team F completes steps 44-57 of the Clam build instructions
    • Team G completes the Terrain build instructions including steps 1-16
    • Team H completes the Turbines build instructions including steps 1-9
  • Allow time during Play Part 1 for all students to take a turn driving the Hero Robot on the Field. Remind students that they can change the controls to find a Drive Mode that works best for them.
    • You may want to have students practice opening the clam and then moving the pearl to the green tile if the team finishes aligning the turbines faster than the rest of the class. Depending on how quickly the team completes each task, the teacher can choose to extend to the next two tasks.
  • In Play Part 2, you may want to allow extra time and VEX GO Kit pieces for students to design and build an iteration of the forks on the Hero Robot, to help them get the clam open and retrieve the pearl. You can use the Engineering Design Process Organizer to help students document the problem they are trying to solve, their design idea, and how successfully it accomplished their goal.
    • To help students stay focused and organized, you may want to have them check in with you to share their design ideas before they begin building. This way, you can help them evaluate the feasibility of the iteration in the time and constraints of your setting. Ask questions like:
      • How will this change help get the clam open or retrieve the pearl?
      • How much time do you think this will take you to build? Can you build it in the time we have in class?
      • How will you test your iteration to know if it is successful? What will you look for in your next practice drive to know if it is working?
    • You can offer constraints like the number of pieces, or the area of the robot that they can adapt, to help students focus on a small and specific iteration, rather than trying to redesign the entire arm.
    • Hint to students about how the pearl should be tested with the magnet to see if it's magnetic. Allow students to test and experiment with adding the magnet onto the fork of the Hero Robot.
  • The speed of the Hero Robot depends on how slow or quickly the controls are moved in the Drive tab. The slower the joystick is pushed, the slower the robot will move. For more information about remote control driving in VEXcode GO, read the Using the Drive Tab in VEXcode GO article.
  • Think ahead about how you want to structure the Mission Relocation competition. It is recommended for each team to have at least two matches to compete in, so that as many students as possible get to have the chance to be a driver in the competition. To learn more about running a VEX GO classroom competition, see this article.
  • Encourage students to document their learning by drawing or writing about their robot, driving practice, and competition strategy. Use the Blueprint Worksheet (Google / .docx / .pdf) or the Data Collection Sheet (Google / .docx / .pdf) as a basic template for students to take notes. These artifacts can then be used to share student learning and progress with others in the classroom and school community on a bulletin board or student portfolio.
